Propeller Post - 35mm Binding Posts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-16-2013, 10:35 PM - Thread Starter
hillikja's Avatar
$20 Shipped per pair, I have (8) pair available, these sell for $40 retail
Propeller Post 35mm Tellurium Copper with Gold Plating - Pair
•Tellurium Copper with Gold Plate
•35mm long threaded shaft (1.37")
•Use with banana, spade(6.5mm) or cable entry (2.9mm x 3.9mm opening)
•Connect from inside with solder tab or direct solder to post
•Comes with 2 solder tabs (3.4mm), 4 gold plated brass nuts, 4 shoulder washers, 2 flat washers
•Use a 11mm wrench to hold post during mounting (7/16")
•Use a 5/16" diameter hole for mounting (8mm)
•The shoulder washers are used when mounting into a steel plate to isolate the post from the plate
Tellurium Copper is 99.5% Copper (Cu) and 0.5% Tellurium (Te) along with trace amounts of Silver and Phosphorus. Tellurium is added to the copper to improve the metals machinability. Propeller posts are designed by Virtue Audio: www.virtueaudio.com.
hillikja is offline
post #2 of 3 Old 09-20-2013, 05:12 PM
Archaea's Avatar
Quoted: 2842 Post(s)
Liked: 2421
This guy is a good, honest seller.
Archaea is online now
post #3 of 3 Old 10-29-2013, 12:57 PM
dustyhc's Avatar
Hi,
I just PM you about the binding post ... I want to take a few if you still have them
dustyhc is offline
Reply Audio Gear
