_(7) QSC AD-S82 Outdoor Speakers with Brackets or Indoor PA Pro Club DJ -- SEVEN for - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-09-2013, 05:42 PM - Thread Starter
jimmy154's Avatar
All work well.
You can buy any number you want.
Grills have dents, but they can be straightened.
Enclosure have scratches and scuffs.
Drivers look good.
Comes with the brackets in the pictures.
Two out of the 7 have transformer voltage selectors on the back. 7.5 volts through 100 volts and bypass or "x".
These will be $600 shipped or so in the US. $500 is the local pick-up price.
Only two are pictures, but all look more or less the same.
If you want more than two or different ones I can take more pics.
jimmy154 is offline
Reply Audio Gear
