Krell Foundation Pre/Pro....SOLD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-17-2013, 12:39 PM - Thread Starter
907picklist's Avatar
SOLD!!!!!!Lowered price to $5500 that is $1000 off original price for a rand new unit if you can find one..Added some stock photos...For sale brand new in the factory sealed box Krell Industries Foundation pre-amp processor. I won this item in a drawing from Home Theater Review and was shipped straight from Krell. I have not even opened the factory box that is why there are no pictures. I will not have the funds anytime soon to add amplifiers and speakers that would do this processor justice so I figured it would be better to sell it to someone that could put it to good use. These retail for $6500 if you can find them or don't mind waiting. I will ship as soon as payment clears. Great deal at $6000 and I will split shipping with buyer. Possible trades plus cash let me know what you have. Email any questions to j.duncan2@me.com...Thanks
SIGNAL-TO-NOISE RATIO
"A" Weighted 106 dB
TOTAL HARMONIC DISTORTION (THD) Unweighted 20 Hz-20 kHz, +0, - 0.003 dB
INPUTS
ANALOG AUDIO
(1) Pair Balanced via XLR connectors
(4) Pairs Single-ended via RCA connectors
DIGITAL AUDIO
(10) HDMI via HDMI connectors (9 on rear, 1 on front)
(3) EIAJ optical via Toslink connectors
(3) Coaxial via RCA connectors
DIGITAL VIDEO
ANALOG VIDEO
(3) Component Video via RCA connectors
(2) Composite Video via RCA connectors
OUTPUTS
ANALOG AUDIO
(9) Balanced via XLR Connectors
R, L, C, SR, SL, SBR, SBL, S1, S2
(9) Single-ended via RCA Connectors
(1) Zone 2 Output
(2) Single-ended via RCA connectors
DIGITAL AUDIO
(1) EIAJ optical via TosLink connector
(1) Coaxial via RCA connector
DIGITAL VIDEO
(2) HDMI via HDMI connector
Both Include Audio Return Channel
CONTROL/UPDATE
(1) IR Receiver for Remote Control
(1) RS-232 via DB9 Female Connector Straight Wired
(1) RC-5 via 1/8" stereo "trs" Receptacle
(1) Ethernet via RJ-45 Connector
(1) Mini USB used for firmware updates
(1) 12vdc Remote Trigger Input via 1/8" Mono receptacle
(1) 12vdc Remote Trigger Outputs via 1/8 Mono receptacles
DIGITAL DECODING MODES
Dolby True HD
Dolby Digital Plus
Dolby Digital 5.1
Dolby Digital EX
Dolby Pro Logic IIX
DTS-HD Master Audio
DTS-HD High Resolution Audio
DTS 5.1
DTS ES Discrete 6.1
DTS ES Matrix 6.1
DTS Neo:6
PCM 5.1
PCM 7.1
SURROUND ENHANCEMENT MODES
General Admission
Front Row
On Stage
Enhanced Stereo
Orchestra
Mezzanine
Full Range + Sub
Monophonic
Party
RS-232 DB9 Pin Out
1. Data Carrier Detect
2. Received Data
3. Transmitted Data
4. Data Terminal Ready
5. Signal Ground
6. Data Set Ready
7. Request To Send
8. Clear To Send
9. Ring Indicator
RC-5 pin out
Tip = RC-5 data, Ring = +5 V, Sleeve = GND
XLR Pin Out
Pin 1 (ground) Pin 2 (non-inverting "Hot") Pin 3 (Inverting)
Maximum Input
Balanced 6.3 Vrms
Single Ended 3.15 Vrms
Maximum Output
Balanced 16.7 Vrms
Single Ended 8.35 Vrms
Audio Input Impedance
Balanced 58K Ω
Single Ended 58K Ω
Audio Output Impedance
Balanced 100 Ω
Single Ended 100 Ω
Power Consumption
Stand-by 2w
Operation 59w
DIMENSIONS
Inches (L) 16.83 x (W) 17.06 x (H) 3.47
Centimeters (L) 42.76 x (W) 43.33 x (H) 88.1
WEIGHT
18lbs Unit only
8.16kg Unit only
24lbs Shipping Weight
10.89kg Shipping weight
907picklist is offline
Reply Audio Gear
