BNIB Klipsch Synergy F-30's "Pair" $400! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-27-2013, 05:58 AM - Thread Starter
THXMovieMaster4's Avatar
"Brand New in Box - Unopened" Pair of Klipsch Synergy F-30's. Retail is $525/each. If you are familiar w/Klipsch then you know the quality of their speakers and the great sound they put out. I purchased these from an authorized dealer (i'm not positive but you may still be able to register them through Klipsch to get their 5yr warranty because the serial/product # should be registered to that dealer). I bought these to upgrade my Home theater but impulse bought and then changed my mind and decided to upgrade further. My lack of restraint is your savings. These are for "LOCAL PICKUP ONLY!" I will not ship and I required "PAYPAL" payment on day of and before pickup. I have other Klipsch speakers at great prices so check out my other listings. Feel free to contact me w/any questions. Thank you.
SPECIFICATIONS
BUILT FROM: 2010
CROSSOVER FREQUENCY: 1700Hz
DEPTH: 16" (40.6cm)
ENCLOSURE TYPE: Bass-reflex via front-firing port
FINISH: Black Ash vinyl
FREQUENCY RESPONSE: 35Hz-23KHz ± 3dB
HEIGHT: 42" (106.7cm) with feet
HIGH FREQUENCY DRIVER: 1" (2.54cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
INPUTS: Dual binding posts / bi-wire / bi-amp
LOW FREQUENCY DRIVER: Dual 8" (20.3cm), magnetically shielded IMG woofers
NOMINAL IMPEDANCE: 8 Ohms compatible
POWER HANDLING: 150W RMS / 600W Peak
SENSITIVITY: 97.5dB @ 2.83V / 1m
WEIGHT: 60lbs (27.2kg)
WIDTH: 9.5" (24.1cm)
*ALL SALES ARE FINAL! NO RETURNS/REFUNDS!
THXMovieMaster4 is offline
post #2 of 2 Old 09-27-2013, 06:00 AM - Thread Starter
Sorry, forgot to add my location...I'm in Southern Rhode Island.
Reply Audio Gear
