Onkyo TX-NR807 - As new as you can get! (See pictures) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-06-2013, 08:55 PM - Thread Starter
khiser's Avatar
I am selling a TX-NR807 Network Reciever. This unit is in LIKE NEW condition and has been well cared for. The reason for the sale is that I upgraded to a 4K up-conversion unit.
Here are the details from Crutchfield's website (http://www.crutchfield.com/S-nDVGxX23rMT/p_580TXN807B/Onkyo-TX-NR807.html)
Onkyo's versatile TX-NR807 boasts Lucasfilm Ltd.'s THX Select2 Plus certification for guaranteed home theater excellence. Seven channels of high-current power plus state-of-the-art surround decoding team up to deliver intense, hard-hitting sound for your movies, music, TV shows, and video games. Exclusive THX Plus listening modes keep your surround effects detailed and accurate, even at lower listening levels. And you get a host of other entertainment possibilities. If you have a PC network set up, this receiver can enhance the sound of all those entertainment options.
Easy access to PC music, Internet radio, and more
Connect the TX-NR807 to a wired PC network to access music files stored on your computer. You can view track titles on your TV and select the tunes you want to hear using the receiver's remote. You can also enjoy Internet Radio stations over your broadband connection. The 'NR807 is SIRIUS Radio ready, too — just hook up an optional home tuner to receive your favorite satellite radio channels. Or add Onkyo's HD Radio tuner to listen to the free digital over-the-air programming that many AM and FM stations now broadcast.
Add new dimensions to your surround sound experience
Along with the latest high-res surround decoding for Blu-ray soundtrack, the future-ready 'NR807 boasts Dolby® Pro Logic® IIz. This cool feature lets you add an optional pair of front "height" speakers for a larger soundstage with an expanded vertical dimension — a perfect complement to your video games and movies. And this receiver offers Audyssey DSX (Dynamic Surround Expansion). Like Dolby Pro Logic IIz, Audyssey's DSX processing allows you to add a pair of front height speakers — use them in place of back surrounds, or connect optional front "wide" speakers instead, creating an exceptionally broad soundstage for greater home theater impact and realism.
Flexible video connections and 1080p HDMI upconversion
This receiver's 1080p-compatible HDMI inputs let you connect up to 6 digital high-def sources for easy switching. And thanks to analog-to-HDMI conversion, you can pass all of the video sources in your system to your TV via a single HDMI cable. Plus, the 'NR807 can upconvert any non-HD video source, enhancing the picture quality of standard DVDs and older video sources viewed on your HDTV.
Precision auto setup tailors sound to your room
For the most accurate home theater sound possible, Onkyo included Audyssey MultEQ®, a sophisticated automatic speaker calibration system. The 'NR807 uses the included microphone to analyze sound from up to six different listening positions, then automatically adjusts level, equalization, and delay settings for each of your speakers. You get precise response across a wide listening area instead of just a single "sweet spot," so everyone in the room can enjoy optimized home theater sound.
See more info on this item
Highlights:
  • 135 watts x 7 into 8 ohms (20-20,000 Hz) at 0.08% THD
  • THX Select2 Plus certification
  • THX listening modes for optimized surround sound at any listening level
  • Dolby TrueHD, DTS-HD Master Audio, Dolby Digital Plus, DTS-HD High Resolution Audio, THX Surround EX®, Dolby Digital EX, DTS-ES™, Pro Logic® IIx, Pro Logic® IIz, and DTS Neo:6 decoding
  • SIRIUS satellite radio capable (requires SIRIUS subscription and optional SiriusConnect™ home tuner kit)
  • iPod/iPhone iPod® integration (requires optional UP-A1 iPod dock)
  • HD Radio ready (requires optional Onkyo UP-HT1 HD Radio tuner)
  • Audyssey Laboratories' MultEQ six-point auto setup and room calibration system (microphone included)
  • Audyssey DSX processing for enhanced surround sound height and width effects using additional front speakers
  • Audyssey Dynamic EQ™ for fuller sound at lower listening levels
  • Audyssey Dynamic Volume™ mode to keep listening levels steady
  • three-room/three-source output:
  • powered and line-level stereo audio output for 2nd room (using powered 2nd room stereo output allows 5.1 home theater in main room)
  • powered and line-level stereo audio output for 3rd room (using powered 3rd room stereo output allows 3.1 home theater in main room)
  • RIHD (Remote Interactive over HDMI) control via HDMI with compatible components (HDMI-CEC)
  • back surround speaker channels re-assignable for bi-amping front left and right speakers
  • 192kHz/24-bit Burr-Brown digital-to-analog converters for all channels
  • Direct/Pure Audio modes for better stereo sound
  • high-current amplifier design
  • on-screen display for easier system setup and operation
  • DLNA certified for better compatibility with other certified networking components
  • learning/multibrand remote
  • 17-1/8"W x 7-13/16"H x 17-3/4"D
  • weight: 40 lbs.
Connections:
  • 1080p-compatible HDMI switching: 6 in, 1 out
  • 1080p video upconversion with Faroudja DCDi Cinema Enhancement for all non-HD sources
  • HDMI version 1.3a with support for Deep Color, x.v.Color, auto lip-sync, DVD-Audio, SACD, multichannel PCM, and HDMI-CEC
  • component video switching (2 in, 1 out)
  • component video conversion (composite to S-video, or composite and S-video to component)
  • digital audio inputs: 3 optical (including 1 front panel), 3 coaxial
  • 5 audio/video inputs, including:
  • 1 front-panel input with composite video
  • 4 rear-panel inputs with composite and S-video
  • 3 audio-only inputs (including phono)
  • 7.2-channel analog audio preamp output
  • Ethernet port for music and JPEG streaming from a wired PC network
  • RS-232 port for automated control systems
  • detachable power cord
  • 1 pair of main speaker outputs
khiser is offline
Reply Audio Gear
Onkyo Tx Nr807
