*SOLD* Emotiva LPA-1 7-channel amplifier ($400 Auburn, WA p/u) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-25-2013, 02:03 PM - Thread Starter
jephdood's Avatar
Quoted: 31 Post(s)
Liked: 53
I don't have the box anymore and I don't want to ship it. Excellent shape and works as-new. $400 firm.
These had, if I'm not mistaken, substantially bigger power transformers than any of the UPA amps.
SPECS:
Rated Power Output: (All Channels Driven @ 1Khz, 120VAC/ 60HZ supply, THD noted)
Channels 1-5 125 Watts into 8 Ohms (0.04%THD)
225 Watts into 4 Ohms (0.04%THD)
Channels 6-7 50 Watts into 8 Ohms (0.05%THD)
95 Watts into 4 Ohms (0.05%THD)
Frequency Response:
20-20Khz: +/-0.1dB
10-100Khz: +/-1.0dB
Total Harmonic Distortion (THD): (80kHz measurement bandwidth)
Channels 1-5: <0.040%
Channels 6-7: <0.052%
Signal-to-Noise Ratio: >100dB, Unweighted (Full Output Reference)
DC Offset: <1mV
Crosstalk: >75dB
Damping Factor: Approximately 200 into 8 Ohms
Input Sensitivity Range (Gain):
Channels 1-5 29dB
Channels 6-7 26dB
Input Impedance (RCA Input) 47K Ohm
External Trigger Input: 3-12 VDC, center tip of 3.5mm jack is positive
Clearance for ventilation (Back): Minimum 2" / 50 mm
Electrical Power Requirement: 1200 watts @ 115VAC when driven into 8 Ohms
Electrical Power Consumption: 4 Watts (Standby) and 46 Watts (Idle)
Raw Weight: 63lbs / 28.63kg
Shipping Weight: 70bs / 31.81kg
Dimensions: 17" W x 7.75" H x 19" D
432mm W x 197mm H x 483mm D
Thanks for looking. Pics available on request.
-jeff
jephdood is offline
post #2 of 2 Old 12-02-2013, 09:42 AM - Thread Starter
jephdood's Avatar
Quoted: 31 Post(s)
Liked: 53
Cyber Monday sale - $400.
jephdood is offline
Reply Audio Gear
