KLIPSCH SPEAKERS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-11-2014, 04:39 PM - Thread Starter
bobrob5's Avatar
Klipsch floorstanding and center channel speakers.
KG 3.5 Two-way Floorstanding Speakers- Light oak finish/black grilles (pair)
frequency response 36Hz-20kHz±3dB
power handling 65 watts maximum continuous (325 watts peak)
sensitivity 94dB @ 1watt/1meter
nominal impedance 8 ohms
tweeter K-84-K 1" (2.54cm) Polymer dome compression driver
high frequency horn 90°x40° Exponential Horn
woofer K-1002-K 8" (20.32cm) Injected Carbon Graphite cone
enclosure material Medium density fiberboard construction (MDF)
enclosure type Bass reflex via front-mounted port
dimensions 33.5" (85.1cm) x 10.5" (26.7cm) x 11.5" (29.2cm)
weight 39 lbs. (17.7kg)
KV-1 center channel speaker- Black (one)
Two-way KV-1 center channel. Vented design, 2 5.25-in woofers, horn tweeter
FREQUENCY RESPONSE: 75Hz-20kHz±3dB
SENSITIVITY:92dB @ 1watt/1meter
POWER HANDLING:75 watts maximum continuous (375 watts peak)
NOMINAL IMPEDANCE: 8 ohms
ENCLOSURE TYPE: Bass reflex via front-mounted port
DRIVE COMPONENTS: Two-way system using one 1" (2.54cm) magnetically shielded, polymer dome compression driver tweeter with a Exponential cone and two 5.25" (13.34cm) magnetically shielded, poly cone woofers
TWEETER: K-89-KV 1" (2.54cm) Polymer dome compression driver
HIGH FREQUENCY HORN: Exponential Cone
HF CROSSOVER: 2100Hz
WOOFER: Two K-1016-SV 5.25" (13.34cm) Poly cones
DIMENSIONS: 6.75" (17.2cm) x 20" (50.8cm) x 6.6" (16.8cm)
WEIGHT: 13 lbs. (5.9kg)
All in very good condition. You can listen before you buy.
$300 for all three. CASH PICK ONLY. LOCATED IN TOWSON MD.
bobrob5 is offline
Reply Audio Gear
