emotiva x-ref 10 subwoofer under warranty Chicago - AVS Forum | Home Theater Discussions And Reviews
Old 03-17-2014, 12:55 PM - Thread Starter
djrumour's Avatar
SOLD emotiva x-ref 10 subwoofer under warranty Chicago
For sale Emotiva x-ref 10 subwoofer under warranty (3yrs) perfect working condition...9/10
Drivers: (1) 10" long throw woofer with die-cast frame, Butyl rubber surround, 2-inch vented motor structure, and proprietary para-aramid blended fiber cone
Power Output: 300 watts RMS, 500 watts peak
Typical In‐Room Frequency Response: 25 Hz‐200 Hz
Typical In‐Room Output: 112‐115 dB SPL
Nominal input sensitivity: Balanced Input: 1 V ; Unbalanced Input: 500 mv.
Phase Adjustment: 0 to 315 degrees (in 45 degree steps)
Low Pass Crossover: 40-150 Hz (in 1 Hz steps)
Parametric Equalizers: EQ1, EQ2 (independent)
Center Frequency: 25 Hz - 150 Hz (in 1 Hz steps)
Gain: -12 dB to +6 dB (in 1 dB steps)
Q: 0.5 to 5.0 (in 0.1 steps)
Input Voltage: 120 VAC 50/60 Hz or 230 VAC 50/60 Hz auto detecting
Dimensions: Unboxed: 13.625" high x 12.625" wide x 13.625" deep (including 1" high feet)
Weight: Unboxed: 33 lbs.
review: audioholics.com/subwoofer-reviews/x-ref-10
djrumour is offline
Old 06-14-2014, 08:55 PM - Thread Starter
djrumour's Avatar
any locals on avs
bump
djrumour is offline
