Martysub Flatpacks/Veneer Flatpacks - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 62Likes
Closed Thread
post #31 of 393 Old 05-04-2014, 07:24 AM
dogger99's Avatar
How many sheets of MDF do you need for the Minimarty?
dogger99 is offline
post #32 of 393 Old 05-04-2014, 07:29 AM
scstockwell's Avatar
I started to cut one sheet yesterday for my MiniMarty and I suspect I'll need another 1/4 to 1/2 a sheet to complete.
scstockwell is offline
post #33 of 393 Old 05-04-2014, 07:44 AM
I will be completing my MartyCube (SI 18" D4) today and was hoping I could get some iNuke 6000dsp advice. I will also be adding a MiniMarty (SI 18" D4) in a week or two.
I'm planning on having them wired in series for an 8ohm load, which I believe will work out good with both subs. The question I have is how should I setup the iNuke today for when I only have one sub and then in a week or two when I have two subs ? Also, do I need to wire the sub differently while I only have one?
Here is how I plan on wiring them (I've never added a pic so hopefully this works!)
post #34 of 393 Old 05-04-2014, 10:51 AM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Two
chalugadp is offline
post #35 of 393 Old 05-04-2014, 10:54 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Yup that's a 8ohm series.
post #36 of 393 Old 05-05-2014, 10:46 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
After I finish assembling the cabinet for my martycube, can I install the driver and start using it before adding the veneer flatpack?
"In nature there are neither rewards nor punishments; there are consequences."Robert Green Ingersoll
Noman74656's Martycube Builds
My Theater
Noman74656 is online now
post #37 of 393 Old 05-05-2014, 01:40 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Yes,
as long as you take the driver out when you add veneer.
post #38 of 393 Old 05-06-2014, 07:59 AM
dogger99's Avatar
This may help for a cut list....
http://www.delphiforfun.org/Programs/CutList.htm#Download
BacHolz likes this.
dogger99 is offline
post #39 of 393 Old 05-07-2014, 03:47 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Well I finished my 20th flatpack today. Never thought i would get to that number. I have wrecked about 4 pairs of pants will glue, silicone, and other stuff. I don't like wearing a shop apron. Thanks to everyone who has ordered and I will continue to take orders but I am glad they are slowing down. I am not erich , can't do two jobs at once for months on end. cool.gif
post #40 of 393 Old 05-07-2014, 05:21 PM
docbrazen's Avatar
I've always been curious about DYI subs. Flatpacks seem like a good way for a beginner to start. How hard is it to make a sub from a flatpack? Don't laugh but my woodworking experience is limited to assembling Ikea furniture. The clamping, gluing, and drilling part doesn't seem that bad, but how does the finishing part work? I know nothing about paints and finishes. And how do you hide the screw heads?
docbrazen is offline
post #41 of 393 Old 05-07-2014, 05:25 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Well to be fair Erich has all of his flat packs cut by a CNC machine and they fit together like a puzzle, the way you cut by hand and also ensure that the pieces all fit together is a lot more labor intensive. So considering all things I think you've done pretty good Donny!
Of course I know of a CNC machine for hire so if you get tired of cutting them up we could always look at having someone else cutting all of them up for you.
jbrown15 is offline
post #42 of 393 Old 05-07-2014, 06:23 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
If you can assemble ikeA you can do this. If you use screws then you need to fill holes
post #43 of 393 Old 05-10-2014, 07:40 PM
DarkEvil's Avatar
What is the best way to make a whole on the back for the wire to the amp? Anyone has a pix showing the back of their martysub? Thanks!
DarkEvil is offline
post #44 of 393 Old 05-10-2014, 07:48 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Just a 1" or 1.25" hole depending on connector. Use a forstner bit if you have one.
post #45 of 393 Old 05-11-2014, 12:33 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
What would people say is the best way to install the bracing strips? I have been gluing both ends and then sliding into place, but most of the glue seems to come off since it is such a tight fit.
My Theater
post #46 of 393 Old 05-11-2014, 12:52 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Put glue on ends and in place where it will sit. When glue is dry I put dap silicone around the joint. I also use Brad nailer and toe in couple of nails.
post #47 of 393 Old 05-17-2014, 02:33 PM
Boomassiv's Avatar
Quoted: 118 Post(s)
Liked: 50
I was planning on building two mini Martys but the room the wife approved for media use is only 1650cf (if I did the math right 9'x12.5'x14.5').  Is there a such thing as overkill for most of you?  With the room size I wont have a lot of options for locations lol.
Boomassiv is offline
post #48 of 393 Old 05-17-2014, 08:32 PM
jbrown15's Avatar
Liked: 1993
Right now I have a sub that's basically the same size as the full size Marty sub, I have two of them and I'm just finishing build the second two. The third is built and the fourth will be built tomorrow, my room is only 1810c/f. smile.gif
So to answer your question, no there isn't such thing as overkill in my opinion biggrin.gif
jbrown15 is offline
post #49 of 393 Old 05-17-2014, 08:50 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
It's like having a 300 hp Lexus. Power and it purrs
post #50 of 393 Old 05-31-2014, 07:26 AM
BCRSS's Avatar
Quoted: 248 Post(s)
Liked: 184
Wondering if you would consider making packs for the SI 24"? Sealed maybe like Swolephiles si 24? Working 80+ hours a week leaves me no time to get anything done I want.
The Elusive 1099 (L/C/R)---DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is offline
post #51 of 393 Old 05-31-2014, 09:55 AM
jbrown15's Avatar
Liked: 1993
I'm sure he'd be willing to build you one, but the shipping would be really expense I would think.
jbrown15 is offline
post #52 of 393 Old 05-31-2014, 09:58 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Actually if its in flat pack form not too bad. Pm me bcr with zip code and I'll give you a price.
post #53 of 393 Old 05-31-2014, 10:03 AM
jbrown15's Avatar
Liked: 1993
You do realize that even in a sealed box the SI 24 requires something around the size of 16cubic/ft right? Its an IB driver so he requires a huge box! smile.gif
I originally thought about getting two SI 24's but in a ported cabinet they would need at least a 32cubic/ft enclosure eek.gif
jbrown15 is offline
post #54 of 393 Old 05-31-2014, 10:08 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
I'm shipping a finished 30cuft enclosure Monday so I'm aware of size.
post #55 of 393 Old 05-31-2014, 11:22 AM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Oh boy!...Oh boy!!!! Would like to see these fellas when finished! biggrin.gif
blah450 is offline
post #56 of 393 Old 05-31-2014, 12:38 PM
BCRSS's Avatar
Quoted: 248 Post(s)
Liked: 184
Well Box dimensions are 26 x 26 x 26 for Swolephile's so I thought anything around that would be great. My room does not have enough space for anything much larger. 13x16x8 = 1664 C/F. If I went ported I am afraid that my ceiling may come down. eek.gif But 2 sealed 24's running on a Behringer NU6000DSP iNUKE would rock.
BCRSS is offline
post #57 of 393 Old 06-06-2014, 02:27 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Its been shipped and when the buyer is done i will post some pics he takes.
post #58 of 393 Old 06-09-2014, 10:47 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
Thanks! I added the silicone and shot a few nails diagonally into each joint. Feels very secure now smile.gif
My Theater
post #59 of 393 Old 06-09-2014, 10:50 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
I thought I read about this before, but I can't seem to find it now. For connecting to the speaker terminal, there are four connections (-1, +1, -2, +2). Which connections get soldiered to the wires going to the driver?
I am nearing the end of this build, and will finally start posting pictures.
My Theater
post #60 of 393 Old 06-09-2014, 02:31 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
If its bridged it 1plus red , two plus black
Closed Thread Audio Gear
