FS: Speakercraft Wireless Kit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-20-2014, 11:39 AM - Thread Starter
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
I'm selling my two Speakercraft Sonic Air 2.1 wireless kits. I have had them for about 6 months but they are for all intents and purposes, new. One of them I used to run my rears for maybe 3 weeks but then remodeled the room and ran hard lines for the rears. The second kit I was using for my sub but after we rearranged the living room I no longer need it. Here is the PDF info sheet from speakercraft about them:
http://www.speakercraft.com/productd...d/154-sonicair
Both kits have everything they came with, transmitter, receiver, remote, battery, rca cable, wall mount bracket, manual, box, everything. MSRP for them new was $400. Selling price is $110 each shipped to the lower 48, $175 for both. PM me if you are interested. I'll try to get some pictures posted later tonight. feel free to check out my 100% positive ebay feedback: soccer4life21
simp1yamazn is offline
post #2 of 11 Old 08-20-2014, 11:53 AM
GusGus748s's Avatar
Quoted: 411 Post(s)
Liked: 698
I've got 2 pairs of speakers. One for the garage and the other for the pool. Would these wireless transmitters work? How far / distance is the range?
GusGus748s is offline
post #3 of 11 Old 08-20-2014, 11:54 AM
GusGus748s's Avatar
Quoted: 411 Post(s)
Liked: 698
Interested so get 1st dibs in it unless these won't work. Thanks.
post #4 of 11 Old 08-20-2014, 12:01 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
They definitely should. They each have 4 different frequency settings so you can control each pair independently. I'm not sure if you could use one transmitter for two receivers as I've never tried that approach. Worst case scenario is you use a couple of splitters and run both transmitters off of one ouput on whatever you are using as your source. Each receiver also has a line-in so you can plug a source directly into the unit.
The quoted range from speakercraft is 100ft. The farthest I've used them is about 50ft when I moved some speakers outside for a party and they never had a problem.
post #5 of 11 Old 08-20-2014, 01:30 PM
GusGus748s's Avatar
Quoted: 411 Post(s)
Liked: 698
I'm at work at the moment. I need to do some reaseach on them to see if it will work for what I need. I using on AVR to feed my living room, garage and pool are all different zones and music.
post #6 of 11 Old 08-20-2014, 01:57 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Got it. sounds like they should be able to do exactly what you a looking for as one set will plug into zone 2 and the other set into zone 3. The transmitters can take either speaker (amplified) outputs and rca line level outputs.
post #7 of 11 Old 08-22-2014, 08:37 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Hey, any thoughts on the wireless kits?
post #8 of 11 Old 08-22-2014, 06:01 PM
schwts's Avatar
I'll take em if they are still available
schwts is offline
post #9 of 11 Old 08-22-2014, 08:27 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Well I haven't heard from the other guy in over 2 days soo...... PM sent
post #10 of 11 Old 08-23-2014, 02:07 AM
GusGus748s's Avatar
Quoted: 411 Post(s)
Liked: 698
I apologize for not responding sooner, I've been working some late hours and AVS for some reason or another doesn't sent me updates on subscribed threads. If the schwts wants to buy them go ahead. Again I apologize for not responding sooner.
post #11 of 11 Old 08-23-2014, 08:12 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
*sold*
Reply Audio Gear
