Dune HD Smart D1 Media Player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-30-2012, 03:27 PM - Thread Starter
philexile's Avatar
Up for sale is a Dune HD Smart D1 Media Player. It is brand new and has never been used. I bought it around this time last year and never ended up installing it.
I accept PayPal for payment. No eChecks and I will only ship to a confirmed address.
I will ship to anywhere in the United States or Canada. UPS Ground shipping is free to anywhere in the continental United Sates. If you are elsewhere or in Canada, you are responsible for the shipping costs.
I've never sold here before, but Fudoh can vouch for me and I have an excellent eBay profile; see below:
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=pfalco
Thanks for looking. See below for information on the device:
Key Features
The newest Sigma Designs 8642/8643 media processor: enjoy excellent playback and performance of interactive features.
HDD player: connect an HDD to the player and play content directly from the HDD.
Network player: connect the player to a local network and play content directly from PC or NAS (UPnP, SMB, NFS).
MKV player: play HD and SD video in a popular MKV format and other modern video file formats, including top quality HD video with very high bitrate.
RealD: watch 3D video in this ultra modern format used in cinema for the latest movies.
HD audio: enjoy top-quality audio tracks (Dolby True HD, DTS HD Master Audio, LPCM, FLAC).
3 USB ports: conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices.
eSATA port: connect an HDD via the most efficient eSATA interface.
Internal HDD option: use an optional 3.5" SATA HDD installed directly inside the player.
USB slave port: easily and quickly transfer files between the HDD in the player (when installed) and a PC.
SD card slot: easily play media files on SD memory cards from your camera or other devices, or use an SD memory card as a local or system storage (required for BD Live function).
HDMI 1.3: ensure the best possible quality of HD video and HD audio.
A rich set of standard A/V connectors: use S/PDIF optical audio, stereo audio, component video, composite video outputs to easily connect any A/V equipment.
Extended support for Dolby True HD and DTS HD Master Audio: output bitstream (up to 7.1 channels) or decode to LPCM (up to 7.1 channels) for maximum flexibility when connecting audio equipment, and for extended support of advanced playback features (such as Picture-in-Picture).
Video output flexibility: output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
Upscaling: high quality upscaling of DVD and any other SD video content to Full HD (1080p) or other HD resolution.
File browser: convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
The best basis for multi-component Dune HD Smart system: built-in VFD display and extended support for Dolby True HD and DTS HD Master Audio help to build the most feature-rich solution.
Extra Functions
High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey's Audio APE, WAV/PCM, DTS, etc).
Playlists: build playlists from your folders, use your own playlists, use repeat and shuffle functions.
NAS function: access files on storage devices (HDD, optical drive, etc) attached to the player from the local network (using SMB or FTP).
**********: use built-in ********** client to download files from P2P networks.
Customizable user interface: work with media collections using cover art and icon browsing (with Full HD graphics).
Flash applications: extend the player functionality with FlashLite applications.
Internet radio: playback and record various Internet radio stations (HTTP/MP3).
IPTV: playback and record IPTV streams (multicast UDP/RTP) from your Internet provider (check availability of multicast UDP/RTP streams with your Internet provider).
Digital TV option: playback and record Digital TV channels using an optional Digital TV USB dongle (Digital TV USB dongle is not included; this option can be purchased separately).
Internet browsing: view Internet Web sites on your TV using the built-in Web browser (built-in Web browser has limitations and may not allow to view some Internet Web sites).
Modular System of Player Configuration
Dune HD Smart players allow to create custom configurations based on the primary (head) unit like Dune HD Smart B1/H1/D1 and several optional extension modules of choice, which can be combined to form an integrated player.
The Dune HD Smart player itself is a head unit which can be extended at user's desire with extension modules, such as the following:
Dune HD Smart HE (adds the option for easy installation of SATA 3.5" HDD with hot swap feature).
Dune HD Smart ME (adds the option for installing different additional modules, in particular, for reception of satellite, cable or digital terrestrial TV).
Dune HD Smart BE (adds the option for Blu-ray/DVD/CD playback) (including commercial Blu-ray/DVD discs).
Extension modules can work exclusively with the head unit (Dune HD Smart player) and use a common control system, implemented via the head unit. The number of connected modules may vary in a wide range: the user can compile his/her own Dune HD Smart system of e.g. two, three and even six components.
In order to group SMART devices by 2 or 3 horizontally, special mounts can be used. For example, a group of 3 modules, including the head unit, combined this way, will comprise a new player of a standard size like the model Dune HD Max.
Besides, grouping the required number of modules allows to supersede the functionality of Dune HD Max, providing more flexibility at the same time. In particular, the modular approach provides the possibility to group modules in any order at any time depending on user's demands, as well as replacing (upgrading) particular modules instead of replacing the entire set of equipment.
Package Contents
Dune HD Smart D1 media player
Remote control (batteries may not be included)
HDMI cable
AV cable
Power supply cord
External power supply
Quick start guide
philexile is offline
Reply Video Source Items
