URC MX-980 Remote Control - AVS Forum | Home Theater Discussions And Reviews
Old 08-09-2012, 12:16 PM - Thread Starter
the crane's Avatar
For sale is a used MX-980 remote control as well as the charging station. Remote is in great condition and works perfectly. The rubber guard over the USB cable plug is partially torn off, but doesn't effect usage at all.
I also have access to the URC Dealer website which I will provide for you to download the Total Control software and add on packages from URC directly.
Located in the Chicagoland area, make an offer. Photos available upon request.
I Golf
the crane is offline
Old 08-20-2012, 09:36 AM
paulba's Avatar
Do you still have MX-980?
paulba is offline
