4x1 HDMI® Switch w/ TOSlink & Digital Coaxial Audio Output (Audio Return Channel/3D/CEC Support) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-02-2013, 11:44 PM - Thread Starter
warrenP's Avatar
Liked: 60
This is a used, and in great condition 4 port HDMI switch, with remote.
It is a Monoprice switch, here is the description:
This 4-way HDMI switch also features Optical TOSlink and Digital Coax output ports to keep your A/V receiver in the loop with new HDMI High Definition systems. This switch is 3D capable and and includes support for the Audio Return Channel and Consumer Electronics Control features. It has 4x HDMI inputs and features a built-in audio converter, which will convert the HDMI audio from any of the four HDMI inputs and distribute it simultaneously to the audio output in HDMI, Optical/TOSlink, and Digital Coax outputs. That way you can integrate any type of sound system, even if it doesn't directly support HDMI audio.
Features:
Supports digital audio output simultaneously - HDMI TOSlink, and Digital Coax
Supports highest resolutions up to 1080p
Supports 225 MHz/2.25 Gbps per channel (6.75 Gbps all channel) bandwidth
Supports 12-bit per channel (36-bit all channel) Deep Color
Supports x.v.Color™
Supports HDCP
Supports Audio Return Channel (ARC)
Supports compressed audio, such as DTS® Digital, Dolby® Digital, DTS-HD Master Audio™ and Dolby TrueHD™
Supports all HDMI 3D video modes
Supports the Consumer Electronics Control (CEC) feature
Buyer pays shipping.
Thanks, Warren
Every man dies. Not every man really lives.
warrenP is offline
Reply Accessories
