ICRON Ranger 2101 USB 2.0 Extender for KINECT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-08-2013, 01:17 AM - Thread Starter
multicamera's Avatar
This is for 1 transmitter, 1 receiver and 1 power supply, a complete Ranger 2101 system.
Works on Macintosh, PC, Linux, any OS that supports USB 2.0. NO drivers required, OS independent, full-speed USB 2.0 over CAT 5e or better up to 333ft.
These were part of a large install and are used but tested and work great. Still sell for over $350 new, save a ton.
This is the one you want, the cheap ones you see on eBay will not work properly (I've tried). Get the real thing.
May have cosmetic blemishes or adhesive residue from previous install, but are tested and guaranteed to work.
From the website:
http://www.icron.com/products/icron-brand/legacy/legacy-2101-2104/
Same chipset used in the Gefen USB 2.0 Extenders. Great for remoting Pro Tools and other Audio Workstations.
USB 2.0 Ranger 2101
USB 2.0 Ranger 2101 (one port) and the USB Ranger 2104 (four port) extends USB 2.0 beyond the desktop, up to 100m over standard Cat 5d UTP cable using ExtremeUSB® technology.
The USB Ranger 2101 and 2104 extenders represent a significant milestone in the USB market supporting USB 2.0 peripheral devices at speeds up to 480 Mb/s over a distance of 100m/330ft, doubling the extension distance of 50m/165ft of the previous generation.
Powered by patented ExtremeUSB technology, the USB Ranger 2101 supports a single device port; the USB Ranger 2104 supports four device ports via an integrated hub. Both solutions enable host computer and peripheral extension over standard Cat 5e UTP cable. Note the remote units require AC power for proper operation. The products ship with the required power adapter.
Applications
KVM extension
USB device sharing: print, scan, storage
Home network integration
Industrial control
Remote desktop USB connections
Automotive telematics
Security: web camera, access control
Digital signage
Contact us for more information.
multicamera is offline
Reply Accessories
