D-Box SRP-130 Motion Platform with USB PC Game Controller Key - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-07-2013, 08:31 AM - Thread Starter
Airhogg's Avatar
The D-Box SRP-130 motion platform was developed specifically for those impassioned by home entertainment, desiring a unique D-BOX motion experience closer to home. This platform is adaptable for existing seating. It offers 4 actuators giving a unique and compelling 3 axes of movement and fits easily under your existing seating. You will experience the full spectrum of motion experience: pitch, roll, heave and intelligent vibrations.  Everything is included in this auction for an out of the box, ready to run experience.  This unit has been used less than a dozen times in a home cockpit flight simulator and is in EXCELLENT condition.  You won't be disappointed in this device!  For a list of all compatible games please visit:
http://www.d-box.com/en/consumer/home_game
Note also that with the separate purchase from D-Box for the D-Box movie controller, this unit can be used for the D-Box movie collection found at:
http://www.d-box.com/en/consumer/home_movies
Features
  • Easy to install
  • Adapts to virtually any chair up to 49’’ wide ***NOTE*** THIS USED UNIT WAS MODIFIED TO FIT UP TO ONLY 40 3/4" WIDE (for recliner or single seat home flight simulator or racing cockpit)
  • Comes with required hardware to custom fit
  • Low profile design blends into almost any decor
  • 3 axes of movement with 4 actuators
  • Perfect for retro-fitting existing furniture
  • For movies and games ***NOTE***  THIS UNIT INCLUDES THE USB PC CONTROLLER FOR GAMES ONLY.  (A separate controller is required for movie use and can be purchased from D-Box)
Specs
  • Customizable Length: 28’’ - 40 3/4’’ / 71 cm - 103.5 cm  ***Optional -- can expand to 49" for use with love seat with purchase of (2) part # (134-0053) from D-Box)***
  • Width: 30’’, fixed / 76.2 cm, fixed
  • Height: 13.7’’ / 34.8 cm
  • Weight: 85 lbs / 39 kg
  • Power requirements: 120V, 50/60Hz, 5.0 AMP
  • Max. load capacity (including seat): 700 lbs / 318 kg
Airhogg is offline
Reply Accessories
