Chief RSMAU Mini Elite Universal Projector Mount - AVS Forum | Home Theater Discussions And Reviews
Old 03-21-2014, 03:39 PM - Thread Starter
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
SOLD - THAT'S WHY THIS LISTING IS CLOSED. SORRY!
http://www.chiefmfg.com/Products/rsmau
Brand new mount (black, brand new) with associated universal mounting hardwear (white, very lightly used). Sells for ~$160, asking $120 or best offer including shipping. Having used several different mounts, I regard this as the best mount on the market. There's a reason the Chief Elite mounts are so highly praised, including by professional installers, on this forum.
For those who are confused about the difference between the various Chief mounts, S refers to this being the smaller-sized but otherwise identical cousin of the heftier RPM (which can handle projectors over 25 lbs), M refers to the micro-adjustment feature (which is super convenient for fine-tuning projector alignment), and U refers to the universal attachment system being included (you can also order a custom mounting plate directly from Chief). Basically, this is the smaller but otherwise identical version of the high-end RPM mount.
Crucially, unlike the competing Peerless mount, this mount offers micro yaw adjustment even if directly ceiling-mounted without an extension pole (can of course also be mounted on an extension pole). The design is also much cleaner than the Peerless mount.
FEATURES
Compact design is smaller than the RPMx Elite by 1/3 and includes all the same features
MicroZone Adjustments make projector registration fast and precise (including flush mount installations)
Integrated cable management through top of mount without additional accessories
Q-Lock Quick Release Lever provides quick connect/disconnect of the projector for service and enhanced security with an integrated key and lock system (4 key options)
SPECIFICATIONS
Adjustments:
Roll: 3°
Pitch: 15°
Yaw: 360°
Certifications: UL Listed
Color: Black
Overall Dimensions (H x W x D): 1.8" x 4.4" x 5.1" (46 x 111 x 129 mm)
Shipping Weight: 5.70 lbs
Solution Type: Universal
Weight Capacity: 25 lbs (11.3 kg)
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
