ButtKicker Platform w/ BK-LFE-KIT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-23-2014, 02:46 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
I no longer have a need for this platform because we are finishing the basement and building a dedicated theatre room. Platform dimensions are 82 x 43 x 4.5. Top is finish grade plywood. Frame constructed of 2X4's attached with glue and screws. Very solid!! Padded and carpeted. Carpet can be easily changed to match. Rope lighting around the base. Rubber isolation feet attached with approx. .5 floor clearance. Will work on hard floor or carpeted area.
I will sell with or without BK-LFE-KIT but would prefer with. Lol - no shipping, local pickup only
I had my chairs attached directly to the platform but its works just as well just resting on top. This set up will literally shake your brain to the point its uncomfortable (if really turned up) - so plenty or power and vibration.
The LFE kit sells on Amazon for $600 and my material cost was about $200. Spend a weekend building it. I am flexible on price - something fair. Let me know if you have any questions.
ID:	327442   Click image for larger version
ID:	327450   Click image for larger version
ID:	327458   Click image for larger version
ID:	327466   Click image for larger version
Ryan Rosser Byorick is offline
post #2 of 5 Old 10-27-2014, 07:39 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
bump.....
post #3 of 5 Old 10-30-2014, 12:29 PM
wlhungdude's Avatar
Quoted: 44 Post(s)
Liked: 84
location?
We never grow until we're pushed outside the boundaries we are comfortable within...
wlhungdude is offline
post #4 of 5 Old 10-30-2014, 04:02 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
Lancaster Pa
post #5 of 5 Old 11-11-2014, 05:50 AM
rboster's Avatar
Quoted: 378 Post(s)
Liked: 234
I am looking for a BK amp. Let me know if you would like to sell it separately?
"Retired" AVS Moderator
rboster is offline
Reply Accessories
Buttkicker , lfe , platform
