Digitalis Vision II HTPC Case - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-29-2013, 05:09 PM - Thread Starter
realtight's Avatar
Quoted: 31 Post(s)
Liked: 77
Digitalis Vision II HTPC case
  • Drive Bays: 2 - 5.25", 1 - 3.5", 3 - 3.5" internal
  • Fan Bays: 4
  • Motherboard Type: ATX
  • Other: 2 - USB, audio in/out
Vacuum Florescent Display - The vacuum fluorescent display (VFD) VK202-25 from Matrix Orbital shows 20 characters x 2 lines. It numerous different color filters which are included with the case.
MSRP w/display was over $400 when new.
The case is a full ATX unit, supporting one external 3.5", two external 5.25" and three internal 3.5" drive bays. The flip-up front panel hides the external bays (has room for 6 inside hd's if you can find or add another HD cage), two USB ports, and audio jacks. In the center of the front panel is a large display window for the included fluorescent display and an IR receiver and transmitter. The power switch is a push button illuminated by a red or blue LED (blue installed). The front panel is manufactured from 3/8" anodized black aluminum. The rest of the case is manufactured from galvanized steel and then powder-coated on the outside. This case is built like a tank, much higher quality then most computer cases you'll find on the market today.
http://www.ebay.com/itm/171047701102?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
realtight is offline
Reply HTPC Computer Items
