Asus e350m1-m pro Motherboard / 4Gb memory stick/ Great for Roll your own Synology build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-29-2013, 10:52 AM - Thread Starter
ilpostini2's Avatar
Quoted: 41 Post(s)
E35M1-M PRO with 4Gb memory.
I bought this to try the Synology build on and it works great.
There are no issues with the board and I'm including a 4Gb memory stick with it.
Buyer pays shipping and PayPal fees.
CPU
AMD APU E-350 Dual-Core onboard Processors
AMD Cool 'n' Quiet™ Technology
Up to 2 "Bobcat" cores, FT1 BGA
Chipset
AMD FCH A50 (Hudson M1)
Memory
2 x DIMM, Max. 8GB, DDR3 1066 Hz Non-ECC, Un-buffered Memory
Single Channel Memory Architecture
* Refer to www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists).
System Bus
Up to 2.5 GT/s UMI Link
Graphic
Integrated ATI Radeon™ HD 6310 GPU
Multi-VGA output support : HDMI/DVI/RGB ports *1
- Supports HDMI with max. resolution 1920 x 1080 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1080 @ 60 Hz
- Supports RGB with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1024 MB
Hardware Decode Acceleration for H.264, VC-1, and MPEG-2
Supports DirectX 11
Expansion Slots
1 x PCIe 2.0 x16 (x4 mode)
1 x PCIe 2.0 x1
2 x PCI
Storage
Built-in Controller :
5 x SATA 6Gb/s port(s), gray
1 x eSATA 6Gb/s port(s), red
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)
Audio
Realtek® ALC 887-VD2 8-Channel High Definition Audio CODEC *2
- Supports : Multi-streaming, Front Panel Jack-retasking, Anti-pop Function
Audio Feature :
- Optical S/PDIF out port(s) at back panel
USB Ports
ASMedia® USB 3.0 controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
12 x USB 2.0 port(s) (4 at back panel, black+red, 8 at mid-board)
ROG Exclusive Features
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
ASUS EPU :
- EPU
Turbo Key
Turbo Key II
TurboV
ASUS Exclusive Features :
- AI Suite II
- Anti-Surge
- Low EMI Solution
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 6Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
4 x USB 2.0
1 x Optical S/PDIF out
3 x Audio jack(s)
Internal I/O Ports
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x COM port(s) connector(s)
5 x SATA 6Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s)
1 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x parallel port connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x Turbo Key II switch(es)
Accessories
User's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x CPU FAN
BIOS
32 Mb Flash ROM , UEFI BIOS, PnP, DMI 2.0, WfM 2.0, ACPI 2.0a, SM BIOS 2.5
Support Disc
Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor
uATX Form Factor
9.6 inch x 7.2 inch ( 24.4 cm x 18.3 cm )
Note
*1: Dual VGA output support: RGB & DVI, RGB & HDMI.
*2: Choose the chassis with HD audio module in front panel to support 8-Channel audio output.
ilpostini2 is offline
Reply HTPC Computer Items
