Hi Axel & Nyal,
Does the box do 2 independent settings for 4 outputs or is it global settings for all four outputs? My front subs are going to be farther than back subs therefore looking for a unit that can apply separate delay for each pair of outputs.
Vinod.
This is dependent on the plug-in you will use. I am not sure if/which one Nyal has one included in his offer. There are numerous ones available.
I use the '2.1 Advanced' plugin for my box that has 2 in / 4 out. I can set delays by output pair and I believe by also individual output. (The settings in this plugin are very tweakable.)
Since Nyal's box here is wired for 1 input, you may have to physically bridge the inputs (which would be easy to do), if you cannot do it with the 2.1 adv. plugin or see if another plugin would work better for your situation (with no rewiring needed).
Hope this helps.
____
Axel
You have insufficient privileges to reply here.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
