DALI HELICON 400 5.1 HOME THEATER SPEAKERS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-05-2012, 08:47 AM - Thread Starter
hillsdalefarm's Avatar
Beautiful cabinets without a single scratch.
The sound is magnificent!
The Dali Helicon 400 are floor-standing main speakers. This 2-way system with two 6.5'' woofer/mid range units and the specially developed Helicon high frequency module containing a ribbon tweeter and a 1" soft dome tweeter is a true DALI Helicon. Each woofer is housed in its own chamber and the crossover network is placed inside in a separate third chamber to protect the delicately handmade and hard-wired components from any vibration induced by the extreme pressure waves inside the enclosure. The enclosure is extremely inert and non-resonant-made from MDF and with several layers glued together under pressure to ensure a complete non-resonant enclosure for the high quality speaker units. The sturdy base is fitted with threaded inserts for the included spikes
No boxes but have all the manuals.
Local pickup or will meet half way if within reason.
More pictures available.
Kansas City area.
hillsdalefarm is offline
post #2 of 2 Old 09-05-2012, 10:29 AM
paradigm21's Avatar
Where are you located?
paradigm21 is offline
Reply This and That
