Linksys CM100 Cable Modem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-05-2013, 12:02 PM - Thread Starter
richeydog's Avatar
I have a Linksys CM100 cable modem for sale. It was bought from Linksys Homestore/refurbished in 2011. Used it with Comcast on two different occasions... once in 2011 for the entire year, and for the first 6 months of 2013. Working fine.
I would still be using it with Comcast, but they don't support this modem anymore. It has been put on "end of life" status. It should, however, be usable with other isp's. Check with your local cable internet provider to make sure it can be used on their network.
Also included:
- Power Adapter
- Ethernet Cable
richeydog is offline
post #2 of 2 Old 01-13-2014, 12:01 AM
bwanatikh's Avatar
Hi
am Gerald From Kenya.do you still have the linksys CM100 cable modem? am interested.Let me know.
bwanatikh is offline
Reply This and That
