Audio Power Industries Power Wedge Ultra 115 Power Conditioner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-16-2013, 12:52 PM - Thread Starter
Nosmo4u's Avatar
Up for consideration us a awesome power conditioner made by Audio Power Industries. If you are reading this you are in the know regarding line conditioners and these baby's do not come up for sale very often. This Ultra 115  in great condition and includes the power cord. Call or text Michael @310-971-0759 Ground shipping is additional and varies from location to location but no more than $70.00
The Power Wedge Ultra 115
Designed to support the higher power needs of a television or other high wattage equipment.
One 300 Watt, four 120 Watt, and four amplifier outlets.
Dimensions: 5.25" high x 12.5" deep x 17.5" wide. Weight is approx 65 lbs
Asking $795.00
The API Ultra Series features:
  • A proprietary isolation transformer configuration that provides maximum common mode cancellation of unwanted signals through fully balanced operation.
  • A separate isolation transformer is used on each isolated outlet for complete inter-component isolation.
  • A unique non-resonant filters designed specifically for audio and video applications clean the incoming AC power.
  • Each isolated outlet is filtered with its own proprietary high frequency filter for maximum noise reduction.
  • Individually configurable isolated outlets allow the selection of either balanced or polarized AC.
  • Special outlets for amplifiers designed to ensure maximum current flow.
  • Protection circuitry including metal oxide varistors (MOVs) and multiple circuit breakers.
  • Metal chassis for maximum shielding against radiated noise combine with full RFI grade internal shielding between each isolated outlet.
  • 12 gauge detachable power cord utilizing a high capacity locking Neutrik connector.
Nosmo4u is offline
Reply This and That
