Niveus Rainier HD Media Server. Water Cooled.. BluRay $5,499 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-08-2014, 03:14 PM - Thread Starter
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
Selling a New Niveus Rainier HD Media Server. This is the later version with Windows 7 and Blu-Ray Drive and HD Tuner. This PC is beautiful....so beautiful and built like a tank. Dead Silent with it's Water Cooled design, and heat sinks. Retail was $5,499 . The water cooled case itself is worth close to asking. Fresh install of Windows 7 with Media Center. It can also run XBMC or pretty much any other HTPC based front end...vortexbox....whatever. With the ample amounts of outputs, and Blu-Ray support, you can do about anything with it. Use it as it, or configure it as you want for your HD audio and video setup.
Both HMI and 8 Channel Audio out.
DVI and Component if you need!
Built in Wireless
Gigabit Ethernet
RS-232 Control
HD Tuner/PVR
IEEE 1394
1080p and High Def Audio (TruHD, DTS HD Master).
Some more info...and a review:
http://www.soundandvision.com/content/niveus-rainier-hd-media-server
barhoram is offline
Reply This and That
