100" Carada Home Theater Front Projection Screen - Fixed Frame - 16:9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-27-2012, 12:39 PM - Thread Starter
KCWolfPck's Avatar
I am no longer running a front projection system and would prefer to sell my screen locally to avoid shipping costs. The screen was originally for $780 and is of very high quality. The screen is still in perfect condition and comes with all mounting hardware. The screen has been packed in it's original packaging for transportation as pictured below. Of course, a prospective buyer is welcome to inspect the pieces prior to purchase.
Here are specific details about the screen.
Brand & Model: Carada Criterion Series
Aspect Ratio: 1.78 to 1 (16:9)
Viewing Surface Dimensions: 87.2 inches wide by 49.0 inches high
Outside Frame Dimensions: 93.9 inches wide by 55.7 inches high
Screen Surface: Brilliant White 1.4 Gain
Criterion Series
The Carada Criterion Series projection screens bring an even higher-end look to your home theater. The 3-1/4 inch wide by 1-1/2 inch deep frame has a bevel on the front, inside edge that brings the edge of the frame right down to the surface of the screen.
Criterion Series projector screens are covered with Carada's Black Holeâ„¢ velvet trim to absorb any overspill light from your projector.
The projection screen surface material snaps to the rear of the screen frame to give you a perfectly flat viewing surface, and the frame itself is extremely strong and mounts flush against your wall.
More information available at: http://www.carada.com/Projection-Criterion-Series-Projector-Screens.aspx
LOCAL PICKUP IN FREDERICKSBURG, VA (Washington, D.C. area)
KCWolfPck is offline
post #2 of 2 Old 06-28-2012, 05:10 PM - Thread Starter
KCWolfPck's Avatar
Reply Display Devices
