PANAMORPH - FVX200OPT - OPTOMA CUSTOM FIXED LENS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-09-2012, 11:12 AM - Thread Starter
tripod8383's Avatar
Great anamorphic lens for home theater, barely used. Set up on a slide rail for easy placement. Works great, converts from the standard 16:9 format to the 2.35:1 format of major motion pictures. No scratches or wear at all, some minor dust.
http://www.neobits.com/panamorph_fvx200opt_optoma_custom_fixed_lens_kit_p2679160.html?atc=gbs
More photos to come.
tripod8383 is offline
post #2 of 3 Old 07-31-2012, 06:30 AM
jam1974's Avatar
Will it work with projector Optoma HD80 and what is the difference between the F200SYS vs FVX200OPT
jam1974 is offline
post #3 of 3 Old 07-31-2012, 08:40 AM - Thread Starter
tripod8383's Avatar
Hey,
The difference between the F200SYS and the FVX200OPT is the F200SYS comes with a projector mount. http://www.panamorph.com/8-support/lens-comparison They both come with a slide rail and have all the same throws. I build an aluminium mount to secure to the projector as well, which I will provide. The Optoma HD80 is anamorphic ready, so yes the lens will work with it.
Reply Display Devices
