Kuro 600 MINT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-06-2012, 06:52 AM - Thread Starter
dazedndallas's Avatar
Looking to upgrade to 3d TV. Text 214 7 55 5967 2200 MINT CONDITION!!
PLANO,TX
60-inch Full HD KURO Monitor
KRP-600M
Overview
Reviews
Support & Pictures
Extensive versatility, uncompromised picture quality.
Just 64 mm thin, this 'HD ready 1080p' KURO screen is as versatile as you need it to be, making it the ideal candidate for use in a private home theatre, a living room or a professional setting.
As part of our KURO line-up the KRP-600M displays the deepest blacks and reproduces the most vivid colours, resulting in an unparalleled level of contrast.
The KRP-600M can recognise light, can tell day from night and analyses on-screen content in real time. The monitor features an enhanced Optimum Mode with optical light sensor for automated adjustment of picture settings according to the lighting conditions in the room and the actual image on the screen, resulting in the best viewing experience.
For those of you who are keen on picture purity, the new PURE AV selection mode brings the input signal to the screen as direct as possible, bypassing all typical picture enhancement processing.
Greater convenience is at your fingertips, too. An integrated KURO LINK function enables you to control compatible connected devices through the straightforward remote control.
Additionally, the KRP-600M features IP control for operation via a PC or other controller through a network, while the Web server function even enables access and control via a remote PC web browser. Two HDMI inputs enable a quick and convenient connection to a broad range of source devices.
Specifications
Control KRP-600M
Display Languages English, French, German, Spanish, Italian, Dutch, Swedish, Portuguese, Greek, Finnish, Russian, Turkish, Norwegian, Danish, Japanese
Remote Control Preset (TV, VCR, STB, DVD, DVR, BD)
KURO LINK Yes
IP Control Yes
Room Light Sensor Yes
Power Management (for PC) Yes
Main Features KRP-600M
Diagonal Screen Size 60-inch / 152 cm
Full HD (HD Ready 1080p) Yes
HD Digital Film Direct 24 Yes
Resolution 1,920 x 1,080p
Contrast Ratio Extreme
Speakers Optional high-grade side speakers available
Input Terminals 2 x HDMI, 2 x Component Video, 1 x RCA Audio, 1 x PC, 1 x Ethernet (for IP Control), 1 x DVi, 1 x RS-232C
Output Terminals 1 x Speaker
Intelligent Brightness Control Yes
Optimum Mode Yes (Enhanced)
ISF Calibration Ready Yes
Multiscreen Options (PiP/PaP) Yes
Dimensions (W x H x D) 1,465 x 876 x 64
Weight 49,9 kg
Power Consumption (in use/standby) 486W / 0,4W
Power Requirements 100 - 240V (50/60Hz)
Picture KRP-600M
Ultra Black Panel Yes
Direct Colour Filter 3+ Yes
Deep Waffle Rib Structure Yes
Intelligent Mode Yes
Colour Temperature Adjustment Yes
Noise Reduction Yes
AV Selection Optimum, dynamic, standard, movie, sports, pure, game, user, ISF-DAY, ISF-night, ISF auto
Audio KRP-600M
Audio Output Power 9 W + 9 W
Subwoofer Out Yes
Control KRP-600M
Energy Save Mode Yes
dazedndallas is offline
Reply Display Devices
