Seymour AV Center Stage XD screen material (Angle cut & enough for 131" Diagonal) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-13-2013, 08:39 PM - Thread Starter
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
Now is your chance to get an AT screen! I purchased the Seymour AV Center Stage XD screen material from MKTheater when he went to a bigger size. I ended up buying a retractable screen and don't need the material.
The screen was angle cut to eliminate any chance of moire. It is 118" x 68 1/2" and has staple holes around the edges. It will make a 114" wide 16:9 screen (131" diagonal) or can be cut shorter for a 2.35 screen. If you want a smaller screen, just stretch it on your frame and trim the excess.
An angle cut for this size screen requires 12+ linear feet plus the extra cut charge. This screen will save you around $100+!
Shipping will be $40 flat rate to anywhere in the continental US. It's rolled up in a shipping tube ready to go.
Thanks for looking!
Seegs108 is offline
Reply Display Devices
