Benq W7000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-08-2013, 06:28 PM - Thread Starter
curtishd's Avatar
Quoted: 163 Post(s)
Liked: 24
I am selling my Benq W7000. It is razor sharp and no issues at all. One of the best DLP and 3D dlp projectors out there. I can e-mail any pics or even video of the projector in action at your request. There are about 500 hours on the current lamp/projector.
Specs:
rojection System DLP®
Native Resolution 1080P (1920 x 1080)
Brightness* 2000 ANSI lumens
Contrast Ratio 50000:1
Display Color 1.07 Billion Colors
Lens F=2.48-2.81, f=24.1-36.15mm
Aspect Ratio Native 16:9 (5 aspect ratio selectable)
Throw Ratio 1.62-2.43 (55.7”@2m)
Image Size (Diagonal) 28”-300”
Zoom Ratio 1.50:1
Lamp (Normal/Economic Mode)* 2000/2500 hours
Keystone Adjustment 1D, Vertical ± 10 degrees
Resolution Support VGA (640 x 480) to WUXGA (1920 x 1200)
Horizontal Frequency 31K-92KHz
Vertical Scan Rate 23-120Hz
Lens Shift V: ±125% Max, H: ±40% Max
Interface Computer in (D-sub 15pin) x 1
HDMI v1.4 x 2
Component Video x 1
S-Video (Mini Din 4 pin) x 1
DC 12V Trigger x 1
RS232 (9pin) x 1
Dimensions(W x H x D) 16.85" x 5.71" x 12.48" (428 x 145 x 317 mm)
HDTV Compatibility 720@50P/60P, 1080@50i/60i/24p/30p/50p/60p
Video Compatibility NTSC, PAL, SECAM
Weight 6.7kg (14.8lbs)
Audible Noise 33/28 dBA (Normal/Economic mode)
Power Supply 100 to 240 VAC
Power Consumption 416W, Standby<1W
On-Screen Display Languages English/Français/Deutsch/Italiano/Español/Русский/繁體中文/简体中文/日本語/한국어/svenska/Nederlands/Türkçe/ čeština/Português/โปรตุเกส/polski (17 Languages)
Picture Modes Cinema Mode/Dynamic Mode/Standard/User 1/User 2/User 3/3D
Accessories (Standard) Remote Control w/ Battery
Power Cord (by region)
User Manual CD
Quick Start Guide
VGA (D-sub 15pin) Cable
curtishd is offline
post #2 of 2 Old 03-19-2013, 03:57 PM
SOWK's Avatar
Quoted: 506 Post(s)
Liked: 430
You know you can buy a brand new one for less...
Amazon.com even has it at this price. ($1800)
Not trying to be mean, but you have to price to sell.
jkyte likes this.
SOWK is offline
Reply Display Devices
