Panasonic TC-P55ST50 Viera 3D Plasma 55" - AVS Forum | Home Theater Discussions And Reviews
Old 04-26-2013, 08:36 PM - Thread Starter
wizzack's Avatar
Quoted: 104 Post(s)
Liked: 241
Excellent condition from a smoke free home. Includes original manual, remote, power cord and one pair of 3D glasses. Cherry Hill NJ/Philly area.
VIERA ST50 Series 3D plasma TV - 1080p (FullHD)
The display alternately shows images for the left and right eyes. The left and right lenses of the eyewear open and close in sync with this display timing to show separate images to the left and right eyes. By repeating this action at high speed, the brain perceives 3D images. And because this method displays Full HD 3D images just as they are, both eyes receive 3D images in high, Full-HD quality. This original Panasonic technology detects image movements like the human eye, and optimizes the drive accordingly. By achieving instantaneously powerful light emission rather than finely divided emission, it reduces the afterimages that cause blurring. As a result, fast movement is reproduced with excellent clarity. Enhancements to the panel and cells help reproduce images with smooth, natural gradation and deep, rich blacks - even when viewed in bright surroundings. In movies, the true, deep blacks faithfully convey the intent of the filmmakers, adding power and realism to the viewing experience.
Active shutter progressive 3D method
2,500 focused field drive
Infinite black pro
Vivid color creation
The brightness, saturation, contrast and sharpness of colors are finely compensated in each scene. Highly vivid colors are produced with hardly any mutual interference. People's faces are also detected, and skin tones are beautifully corrected to ensure soft, natural complexions.
Web smoother
The blurring that often happens in web images is eliminated to produce naturally smooth motion.
2D-3D conversion
Unique Panasonic technology converts 2D images into high-quality 3D images in real-time. The image depth is analyzed from the compositional, color and brightness data of each scene, to convert 2D images into naturally beautiful 3D images. In addition to ordinary TV programs, this method can be used to convert a variety of 2D images - such as web content, Blu-ray Disc media, and photos and movies saved onto SD memory cards - into 3D images with a high level of precision.
3D 24p cinema smoother
Enjoy naturally flowing 24p films and familiar TV-like quality. In plasma displays, increasing the number of frames creates smoother images. When reproducing images from a 24p film source, VIERA's 24p cinema smoother function generates smooth, natural-looking images.
Super slim sub-woofer
The sub-woofer, which is mounted to the rear surface of the panel, delivers robust bass sounds. Its super slim design, helps to keep the entire display attractively thin.
Sound lifting driver
Original Panasonic acoustic-field compensation technology produces highly accurate sound imaging. Matched to human auditory characteristics, the frequency for the bandwidth in which the sound is located is adjusted and the optimal compensation is applied.
Free point operation
More intuitive free-point operation for web browsing, by using the touch screen as a touchpad.
Browser linkage
You can display the same web pages on VIERA and smartphone with easy operation.
Media flick
Enjoy photos, music and movies on VIERA and smartphone anytime.
Simple remote control
This remote features easy-to-see characters and an easy-to-understand button layout. It lets everyone in the house operate VIERA quickly and easily.
Wi-Fi built-in
It is easy to connect to the Internet or a home network by using the Wi-Fi built-in function. There is no need for cords or cables, so the layout is flexible and the room stays neat and uncluttered. Using a wireless connection for VIERA connect and employing the DLNA function make it easy to share photos and movies.
DLNA
A DLNA-compatible VIERA makes network connection super easy. It makes content easy to share by linking equipment over a home network. Enjoy photos, movies, music and more in the living room, bedroom, or any room in the house.
Game mode
Games are much more fun when there's no lag in operation. VIERA automatically chooses settings that provide the optimal image, so you get super-fast response and no delays. Even dark scenes with delicately rendered details are beautiful and easy to see. Game mode makes all of the game apps on VIERA connect even more fun to play.
Media player
Simply insert an SD memory card or USB memory stick into the slot to enjoy previously saved photos, video clips and music on VIERA's large screen. You can also add frames and other effects to your photos and videos, and create slide shows complete with background music. A wide variety of formats are supported, so you can listen to PC-based music files and web movies right on your TV.
Long panel life
One important way consumers can protect the environment is by choosing high-quality product and taking care of it so it lasts for a longs time. A high-quality VIERA HDTV can help.
Eco mode
This mode automatically turns the power off and adjusts the brightness depending on VIERA's operating status. Settings can be configured by selecting eco mode from VIERA tools.
Power saving functions in VIERA Link
The power of each connected device is adjusted depending on usage to reduce wasteful usage.
The above post is 100% medically accurate
31 Days of Horror: 2014 2013 2012 2011 2010 2009 2008
wizzack is offline
Panasonic Viera Tc P55st50 55 Inch Plasma Tv
