Stewart Filmscreens Firehawk 16:9 126" A-T Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-07-2013, 07:13 AM - Thread Starter
beastaudio's Avatar
Quoted: 4159 Post(s)
Liked: 3516
Just what the title says! Get the Firehawk material at a KILLER price!!! Stewart will gladly build out a screen frame for you that will fit the material, all you have to do is give them the serial number and it will work.
UPDATE: I have decided I am willing to sell the frame as well. The frame itself cost about $1,200 but I would be willing to let it all go for $1800. Everything is in absolute perfect condition as well.
beastaudio is online now
post #2 of 2 Old 07-04-2013, 04:08 PM
ten8yp's Avatar
Brandon... hit me up man. I might try to squeeze this in my room. (I have 11 feet (132 inches) but since its A-T I might can make it work. How wide was your room again?
I'm looking to do something in about 2 weeks when I get home from vacation since I can go pick it up.
What are you thinking of getting to replace it?
ten8yp is offline
Reply Display Devices
