2.35 Anamorphic Setup: Projector/Panamorph/AT Screen Material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-03-2013, 10:43 AM - Thread Starter
FungalWarrior's Avatar
Anamorphic Projection Setup. Comes from my large dedicated theater building which has now been converted to a 2 bedroom rental. Home Theater Good...Cash Flow Better.
This setup saw little use. The Projector has probably under 300 hrs on it.
Includes...
1 Optoma HD-8000 Custom Install 1080P projector
1 Panamorph Lens
1 Bolt SMX AT Screen Material
The projector is set up to scale for widescreen internally. It includes a Chief projector mount.
The Panamorph lens has no model number on it but it was their entry level lens from about 4 years ago. It comes with what is left of a Chief Panamorph lens mount...it was bastardized to custom mount with the projector being inset up into a ceiling cavity. Plan on buying a new one...they are pretty cheap.
The Screen was a 172" W 2.35 setup. It is SMX acoustic material. It will NOT include the frame since the frame was custom built and is one piece of metal. It would be prohibitive as heck to ship. If you are in the Pacific Northwest and wish to bring a trailer and come pick it up...it is yours free, or else off to the metal recyclers it goes. Alternatively, we can slice and dice it and you can weld it back together, but it will probably be cheaper to have a metal work guy build you one...or build it yourself out of wood.
Will sell the projector and lens without the screen material for $2200.
Located in Bellingham, WA
FungalWarrior is offline
post #2 of 2 Old 06-04-2013, 12:31 PM
BlazeMaster's Avatar
Interested in selling just the lens alone? Pm me
BlazeMaster is offline
Reply Display Devices
