jorogo - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2013, 03:32 PM - Thread Starter
jorogo's Avatar
Two complete NEC 6PG Plus's, both working, though one hesitates to lock up consistently. Included is a boxful of parts, circuit boards and a set of CRT's, pulled out of another 6PG Plus.
The tubes in the working projectors are sort of o.k. When I use them widescreen at 1080, you can see the center-screen deterioration on mainly the blue tubes. Condition of the spare tubes is unknown.
This would be pickup only in Central Wisconsin, and you'd need strong backs to get one down from the ceiling and one down a few stairs. Since most anyone interested would have to consider travel expenses, I'm keeping the price down to a mere gratuity. If you live close by, you're in luck.
jorogo is offline
