Rare Mr Bob Calibrated Mitsubishi WS-55905 55" 1080i HD Rear Projection Television - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-26-2014, 01:28 PM - Thread Starter
rd92171's Avatar
Mitsubishi WS55905 Diamond Series RPTV
Entire Interior Duvyteen lined
Calibrated by Louis Carliner and Mr. Bob
Red Push Corrected
Film Like Picture
Original owner selling this low hour rare display device. Sparingly used Mitsubishi WS-55905 Diamond Series Rear Projection TV. Film like picture calibrated to perfection by RPTV guru’s Louis Carliner and Mr. Bob. Entire interior Duvyteen lined to eliminate stray light and red push mechanically corrected.
Includes original remote, original manual, protective screen cover and a rare complete hard copy of Mitsubishi shop manual which includes all the calibration and set up codes and complete electrical, mechanical and parts schematic diagrams.
No shipping, pick up only at my home near Wilmington, North Carolina. Must be carried down 1 flight of 14 stairs that leads directly to my garage solely by the purchaser and helper/s.
Buy with confidence from a hassle free, meticulous seller with perfect feedback as both a buyer and seller with high dollar transactions. I will answer all inquiries promptly so please have all your questions answered prior to bidding. All sales are final and there are no returns.
Model Details
The pinnacle of Mitsubishi's Rear Project CRT television line-up was the Diamond Series. The design objective of the Diamond Series is zero compromise - extreme cutting edge performance, features and styling. It is the finest series of projection televisions ever created, and was sold only by the finest dealers.
Features:
•Enhanced Depth-of-Field (EDF) lenses
•Dramatically improved sound
•Exquisitely refined cabinetry
•High gloss finish
•Diamond Shield?
•Format/zoom adjustment (expand and zoom)
•1-event program timer
•AV memory by input
•Front panel MENU operations
•Active AV Network?
•120 minute sleep timer
•IRIS brightness/contrast control
•High/middle/low temperature control (6500?K)
•Auto picture (auto sharpness)
•64 point digital convergence adjustment
•Parental control: V-Chip lock by time with TV lock by time
•2 language ViewPoint? on-screen operating system
•Languages: English/Spanish
•Time/channel display
•Rename the input
•Name the channel
•Caption Types: CC 1-4, Text 1-4
•Closed captioning when muting
•2-tuner Picture-In-Picture (PIP) with TV still, moveable, PIP exchange, audio output, 3-POP/9-POP, split-screen, and channel preview; Sizes: 2 (1/9, 1/16); V-Chip controlled
•Video Type: NTSC and HDTV upgradeable
•3D Y/C comb filter
•Aperture control
•Dynamic beam forming
•Velocity scan modulation (not necessary in models designed for HD signals)
•Diamond Digital Pixel Multiplier?
•NTSC/SDTV selectable scanning: 930i/480p
•HDTV Scanning: 1080i
•Wide band video amp
•Wide band VIF
•Dynamic gamma compensation
•Peak white ACL
•7" CRT
•5-element hybrid multi-coated lens system
•Electrostatic Dynamic focus system
•Diamond Bright screen
•Thin Fresnel lens
•0.52mm fine pitch screen
•Front reflective surface mirror
•Multi-step focus
•Dynamic black level expansion
•110 horizontal viewing angle
•34 vertical viewing angle
•Quick View
•Super Quick View with 9 memory banks
•MTS/SAP reception
•181-channel FS tuner
•Automatic channel memory
•2-way internal loudspeakers
•Surround (simulate/hall)
•Level sound (volume limiter)
•2 antenna RF inputs
•1 front A/V input with S-Video
•3 rear A/V inputs with S-Video
•1 set component video YCrCb input with stereo audio (480i/480p)
•Mitsubishi High-Definition Interface (HDI)?
•1 set HDTV video inputs selectable RGBHV/YPrPb with stereo/audio
•Cable loop (RF) output
•1 monitor A/V output (fixed/variable audio)
•1 set PIP audio output
•1 IR Blaster port Home Theater output
•1 Active A/V Network output
Specifications:
•Three (3) 7” guns (red, green, blue)
•Screen Size (diagonal) : 55" (16.9 widescreen)
•Aspect Ratio : 16:9
•Contrast Ratio : 50:1 (dark room); 27:1 (bright room - 250 lux)
•Speaker : 7" round 3/4" round
•Output Power : 2 x 10W
•Horizontal Resolution : 1200 lines
ID:	136985   Click image for larger version
ID:	136993   Click image for larger version
ID:	137001   Click image for larger version
rd92171 is offline
post #2 of 2 Old 06-27-2014, 12:44 AM
Liked: 0
thank you for your information i like it,if you have any problem than contact your freinds and relative about this.
http:/www.alladsclassified.com] top ten classified website [/url]
GAJJUUSIINGH is offline
Reply Display Devices
