Best screen for LT150 attn: Brubaker and Stewart - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-19-2001, 08:44 PM - Thread Starter
benbell's Avatar
1. 800 DLP lumens
2. 105" diagonal image 16:9
3. full light control
4. seating 15 feet from screen
Been reading this board and haven't come up with any definitive solution. Screen suggestions please (gain, etc)!
Ben Bell
benbell is offline
post #2 of 3 Old 12-21-2001, 05:02 AM
Blake Brubaker - Da-Lite's Avatar
Ben,
I talked with Alan Bell yesterday via the phone to cover these issues. If you need anything else, please let me know.
Thanks for the post,
Blake
Blake Brubaker, CTS
Vice President of Sales
Da-Lite Screen Company, Inc.
Blake Brubaker - Da-Lite is offline
post #3 of 3 Old 12-23-2001, 06:20 PM
KFung's Avatar
Ben,
At 54*96 (a bit more than 105" diagonal), I calculate that you would get around 16 ft-lamberts on a 1.0 gain screen with the spec'ed 800 lumens. This would be enough for you to get almost any gain screen since you have total light control. However, once you do things like disable the clear section on the colour or get your projector "Thumperized," your brightness will probably drop quite a bit. I think at one point I heard numbers in the 600 lumen range. I'm not to familiar with the LT150, so those aren't firm numbers.
In any case, a Greyhawk or HC DaMat may be a little too low gain. They will still produce an acceptable image (over 8 ft-lamberts), but it won't look as bright as a good movie theatre. It would be hard to tell without actually seeing the setup, it may be bright enough and it would let you keep all the advantages of a grey screen. A lot of people have tried the Da-Lite Hi Power, but I don't have enough experience with the fabric to make a recommendation either way.
Another option to consider is the forthcoming Stewart Firehawk. It has the same advantages of a grey screen and it's much higher gain. I think it's somewhere close to 1.3 gain, which would be perfect for your setup.
Kam Fung
KFung is offline
Closed Thread Screens
