Budget Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-27-2001, 03:59 PM - Thread Starter
flavioleoni's Avatar
I'm putting together a HT for my brother with a very tight budget. I decided to go with InFocus LT-500 (USD 2,950). The audio part of the system will be composed of a Outlaw Receiver (USD 399) and Swans Divas 5 speakers system (USD 1,500). Now I need to decide which screen to go with InFocus. Here are its specs: DLP, SVGA (800x600), 2000 lumens, 400:1 contrast.
What are your suggestions for a low cost screen to go with InFocus?
flavioleoni is offline
post #2 of 8 Old 12-27-2001, 04:26 PM
smchan's Avatar
A general rule of thumb for a DLP is a 1.3 gain screen. You didn't specify ratio, masking systems, or fixed frame vs pulldown. For an 80 inch Da-Lite pulldown you're probably looking at $200-$300 and for a fixed screen (16x9 or 4x3) without a masking system, closer to $500.
My suggestion is to visit the websites of Da-Lite, Draper, and Stewart and request screen samples, then hang them on the wall and see what you like best.
Or, of course, you could just hang a sheet on the wall if you're really cheap. :D
Sam
smchan is offline
post #3 of 8 Old 12-27-2001, 05:33 PM
Gary Lightfoot's Avatar
Quoted: 623 Post(s)
Liked: 364
If you want a cheap fixed screen, you can build one yourself for less than $50.
I got the idea from this forum (a guy called JP), so you can do a search for 'blackout' cloth, and see what turns up.
I made an 84" x 47.25" frame from 70mm x 18mm wood, using screws and glue to fix the frame together, then stretched and stapled blackout clothe over it. the gain is about 1 to 1.3 judging from various people on this forum, so should be fine for you.
My pj is a DLP Davis DLS8 and I'm very happy with the picture quality. There are some pics of the screen and frame on my homepage if you're interested.
HTH
Gary.
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #4 of 8 Old 12-27-2001, 07:06 PM - Thread Starter
The main reason (besides the price) why I chose LT-150 was its high lumens (2000), because the room will not be light controlled (with windows and glass doors everywere). In such conditions, is the 1.3 gain adequate? Won't I be losing contrast with such gain?
I guess a fixed screen will do fine.
post #5 of 8 Old 12-27-2001, 10:52 PM
francishsu's Avatar
The LT150 is rated at 800 ANSI lumens, not 2000!
With your room not being light controlled, you may want to consider a Da-Lite high power (2.8 gain!) screen.
francishsu is offline
post #6 of 8 Old 12-27-2001, 11:26 PM
francishsu's Avatar
Sorry, I forgot your original message specified InFocus.. you prolly meant the LP500.
Please disregard my recommendation of the high power screen.
post #7 of 8 Old 12-28-2001, 07:03 AM - Thread Starter
My mistake!!!! The projector is the Lp-500. What screen should I choose for this projector in a non-controlled light room (very bright)?
post #8 of 8 Old 12-29-2001, 05:30 PM
centaur's Avatar
Actually the rule of thumb for DLP is a gain of 1.0 or less. You'll find the screen will reflect some of that ambient light, and more so with higher gains.
centaur is offline
Closed Thread Screens
