Black Material to wrap aroud Beam? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-09-2002, 01:45 PM - Thread Starter
anderdea's Avatar
I am using a D-ILA projector in a room with cathedral ceiling and 6" X 6" beams that tie the walls together, at about a 9' height. The beam closest to my 100" 3 X 4 scree receives a LOT of reflected light from the screen and is very distracting.
Q1: What is the best black material that will absorb the light that I can wrap around the beam? I don't want to paint the beam.
Q2: where can I purchase the material?
Thanks, Don
JVC G11, hushbox, VuTek 3X4 100" screen, AVS 1Hgz HTPC, Dish Net HD6000, HBOHD & ShowTimeHD, Lexicon MC-1 7.1, NHT 2.9's, AC2, 1.5's, DT BP2X Surrounds and Sub, BK amp, Rotel amp, 4DTV "C" band BUD, Pioneer LD, Pronto TSU2000.
anderdea is offline
post #2 of 5 Old 01-09-2002, 11:02 PM
deronmoped's Avatar
The cheapest black material I found was trunk liner at a fabric store. Very black and very cheap. I used it for my border on my screen.
Deron
CRT Videophile
deronmoped is offline
post #3 of 5 Old 01-11-2002, 09:53 AM - Thread Starter
anderdea's Avatar
Deron,
Thanks for the info.
Don
anderdea is offline
post #4 of 5 Old 01-11-2002, 03:49 PM
Guy Kuo's Avatar
The blackest fabric you will find is Fidelio brand black velvet. From nearly any angle it absorbs light very well. It exhibits little if any velvet "sheen" which is seen on other types of velvet.
Guy Kuo
Guy Kuo is offline
post #5 of 5 Old 01-15-2002, 10:57 AM - Thread Starter
anderdea's Avatar
Thanks, Guy.
Do you know where I can find the Fidelio brand black velvet?
Don
anderdea is offline
Closed Thread Screens
