What screen works well with a NEC LT155 LCD PJ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-09-2002, 01:49 PM - Thread Starter
Ron_C's Avatar
Hi,
What screens should i look at to get the best quality picture out of the LT155. That room can be completely dark(dedicated HT room). Thanks.
Ron_C is offline
post #2 of 4 Old 01-11-2002, 07:28 AM
Scott B's Avatar
Quoted: 32 Post(s)
How many real lumens does the LT155 put out and how large of a screen are you desiring? Assuming that you can get 15-20 footlamberts, a grey screen such as the Da-Lite High Contrast, Stewart GrayHawk, or perhaps even the new Stewart FireHawk would be your best bet.
Scott B is offline
post #3 of 4 Old 01-11-2002, 10:08 AM - Thread Starter
Ron_C's Avatar
Hi,
It has 1200 Lumens and a 400:1 contrast ratio. Hope this helps. What screen would you recommend to have a 80"x60"(4:3) screen. Thanks
Ron_C is offline
post #4 of 4 Old 01-11-2002, 10:42 AM
Scott B's Avatar
Quoted: 32 Post(s)
You should be able to get very good results with a GrayHawk. I have seen my Sanyo PLV-60 on a large microperforated GrayHawk and it really did improve the image over a flat white sceen. If money is an issue, the Da-Lite High Contrast should also give good results and will cost significantly less.
Scott B is offline
Closed Thread Screens
