Has anyone designed a masking system with 'Flaps' that rotate 180 degrees? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-02-2008, 07:22 AM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
Searched and seems no one has done this...
I think this would simplify the solutionn a lot compared to other ideas I have seen. It will be a fixed masking though if you consider that the flap is either on or off (with no 'in between') althugh this may work with only incremental rotations of the flaps as well...
I imagine a flap on top and below the screen. For masking, the flaps would rotate 180 degrees and mask the screen...
here is the idea illustrated:
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #2 of 8 Old 09-02-2008, 07:54 AM
FLBoy's Avatar
Quoted: 13 Post(s)
Nifty idea. I've not seen it. Might look slicker if you make the exposed side when not in use match the color of the wall around the screen instead of making both sides black.
FLBoy is offline
post #3 of 8 Old 09-02-2008, 08:49 AM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
Excellent point about the coloring. That's definitely a nice advantage over some of the other solutions I've seen. In my case however the back wall is also black
gnolivos is offline
post #4 of 8 Old 09-02-2008, 08:50 AM - Thread Starter
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
Also, if the top flap doesn't have enough space above the screen, one can always rotate 90 degrees against the ceiling instead!
gnolivos is offline
post #5 of 8 Old 09-02-2008, 09:20 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
I did a masking system like that quite a few years ago (I no longer live in that house). I extended the flaps a couple of inches beyond the right and left edges of the screen and used magnets to hold the flaps in place.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #6 of 8 Old 09-02-2008, 02:02 PM
HDGTX's Avatar
Nice idea, here are some hinge ideas from Lee Valley & Rockler....
Rockler...
http://www.rockler.com/search_result...ultsPerPage=25
Lee Valley:
http://www.leevalley.com/hardware/pa...90&cat=3,41241
Be sure an post photos & text as youtest & build, so we can copy you, LOL
Seriously, good luck with develpoing your ideas!
John
HDGTX is offline
post #7 of 8 Old 09-02-2008, 02:40 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
Do all 2.35:1 movies have the black bars in the same place? I seem to remember that with SD DVD's I would have to adjust the masking when watching different 2.35:1 movies. For example, if one movie had top and bottom black bars that were equal in size, say x, another movie might have a top black bar of x+1 while the bottom was x-1. I haven't paid attention in a long time as I don't feel the need to mask for movies anymore so it may be different now.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #8 of 8 Old 09-03-2008, 11:34 AM
FLBoy's Avatar
Quoted: 13 Post(s)
Yes, but not all 'scope movies are 2.35:1. You'll find a good explanation of aspect ratio here.
FLBoy is offline
Reply Screens
