What Dalite Screen with a BarcoData 701 ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-15-2002, 04:05 AM - Thread Starter
AsM0DeUz's Avatar
Hi
I plan to buy a Dalite HDTV format screen but i've some questions ...
What surface is better with that projector ???
Da-mat (gain 1.1) or cinema vision (gain 1.3)
What are the differences between these 3 models :
Da-Snap
Cinema Contour
Imager
Which one is better ???
Regards
AsM0DeUz is offline
post #2 of 3 Old 01-15-2002, 05:57 AM
Blake Brubaker - Da-Lite's Avatar
My friend,
I will try to answer your questions as you have presented them.
First, the 1.3 gain Cinema Vision material is usually the best choice for a CRT projector. This material does the best job at reproducing colors and has just a little bit of gain to help the CRT projector.
As for the frame, here are a few comments on each.
Da-Snap
This screen is a 1-1/2" square tube frame system and the fabric is snapped to the back and then hung to the wall.
Imager
This frame is a 1 5/8" rounded front extrusion and the fabric adheres to the back of the inner frame section via Velcro.
Cinema Contour
Clearly the best of the three, this frame is a 3" wide 1-1/2" thick frame that has a beveled (angled) edge that extends back towards the screen surface which is attached to the back via snaps. This helps to eliminate shadows.
Which ever frame you choose, please give some consideration to purchasing the frame with our "Pro-Trim" finish. This is a velvet-like finish which helps absorb light around the screen to create a "black-hole" type of affect around the screen. The cost to add this is minimal and it is well worth the money spent.
Hope this helps.
Blake
Blake Brubaker, CTS
Vice President of Sales
Da-Lite Screen Company, Inc.
Blake Brubaker - Da-Lite is offline
post #3 of 3 Old 01-15-2002, 02:26 PM
DRS
DRS's Avatar
Blake,
I currently have a Dalite Matte White Model B 80x60 screen, it has been ok except for the wrinkles in the material. How does the Cinema Vision compare to the Matte White material when it comes to wrinkling in a 80x45 Model B? thanks...
DRS is offline
Closed Thread Screens
