How to measure gain? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-15-2002, 05:51 AM - Thread Starter
centaur's Avatar
Normally the concept of unity gain would mean 100% of the light hitting the screen is reflected, and thus no measurement could be >1..
But in the HT world it seems unity gain is defined as the amount of light reflected by a matte white screen. (which white?) And what effect does a gloss sheen have on gain?
And how can a screen have a gain of 4?! Is it coated with triangular street reflectors?
Is there an objective way to measure gain?
OT: Is Video Essentials the best way to tweak a system? Does it require a light meter? Is there a better way to get color balance?
centaur is offline
post #2 of 4 Old 01-15-2002, 06:34 AM
TimC's Avatar
TimC is offline
post #3 of 4 Old 01-15-2002, 11:00 AM
Iceman's Avatar
And this is exactly why gain should be re-labelled directivity. This would be in agreement with conceptually similar phenomena in acoustics, antennae etc. Unfortunately, gain seems to be an established term that is hard to get rid of.
Iceman is offline
post #4 of 4 Old 01-16-2002, 06:46 AM - Thread Starter
centaur's Avatar
Thank you both.
centaur is offline
Closed Thread Screens
