AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Da Lite Highpower cleaning (http://www.avsforum.com/forum/23-screens/1094109-da-lite-highpower-cleaning.html)
dgaspar 12-09-2008 12:04 PM
Hi guys:
I have been reading this forum for some time and have learned a ton of information. I recently purchased a Highpower screen (mostly due to what I have read here) and absolutely love it. However, my dog licked the bottom of the screen last night leaving a small but seemingly permanent "wet mark". According to Da Lite's cleaning instructions, the spot can be cleaned with water but says that it is very difficult to eliminate streaking. Anyone have any ideas how (or whether) I can remove the spot? Thanks for your help.
WOLVERNOLE 12-09-2008 04:36 PM
Yes, you can remove Spot. Put Spot in the back of your truck, drive him out about 20-30 miles and drop him off at someone's farm.
BTW, we got your question in the other thread. Go view it, and good luck with Spot.
Daniel Hutnicki 12-10-2008 08:53 AM
call Dalite directly and ask them how to clean it.
And No dont get rid of spot
jostenmeat 12-10-2008 11:37 AM
Bad dog!
mdputnam 12-11-2008 08:11 AM
It's a little known fact that the Dalite HighPower screen tastes like chicken!
WOLVERNOLE 12-11-2008 07:45 PM
You mean "it's the 'other' white meat?"
Solfan 01-01-2009 10:29 AM
I just had an issue somewhat like this with my high power, so I tried using some clean towels and hot tap water [from our well] and I thought I'd totally ruined the screen. Calcium and/or iron streaks [and/or water-heater copper?] all over it.
After a quick run to the store, plain distilled water on a heavy bath towel cleaned it up perfectly.
zarak 06-08-2012 09:47 AM
Instead of creating another thread I will post my related question on this one.
What is the proper method of cleaning Da-Lite's high power screen material?
Manufacturer says that it is not recommendable to try to clean the screen. Has anyone tried the method they are recommending?
My screen has a lot of mildew/mold stains on it. Where I live the weather is quite humid, and that might be the reason. This didn't happen with my previous high power material, but well. I ruined the previous one while cleaning it. I just want to make sure that doesn't happen again.
Solfan 06-08-2012 10:40 AM
The link's not working,
I assume that it's a link anyway.
garykagan 06-09-2012 05:58 PM
Does anyone have the link to clean this properly? I have a 5 year old Da-Lite high power and it really needs cleaning. Any movie a white sceen looks streaky and bad. It's really getting to me when I watch movies. any help is really appreciated. I will try calling da-lite next week as well.
airscapes 06-09-2012 07:56 PM
I clean my HP 2.8 every year or so. I use Denatured Alcohol and a couple of micro fiber cloths. No smoking or open flame DA is highly flammable. Have your projector on displaying a 100% white pattern, use the AVS disk or if you can set the blank screen to white that is fine. This helps you see what you are doing. Wet one rag well and wipe a 1 -2 ' square at a time. Bugs can be hard to get off, Hydrogen peroxide works well on these, finish it off with the DA.
Do not crease or rub to hard, let the chemical do the work. I have done this 3 times with no issues. The screen will be like new when you are done, take your time and work in small overlapping areas.
garykagan 06-09-2012 08:29 PM
Mine is a 133 high power diag perm mount. Just must be years of dust buildup in a closed room as nobody ever touches it. I will try this approach. I will have to find some micro fiber cloths. No water, only the DA right?
airscapes 06-10-2012 05:46 AM
I have tried water in the past, it takes a very long time for it to dry in comparison to the DA (minute or 2) so you never know if you are done or not for a couple of days. The screen is covered with billions of micro beads .. so like a window, you do not want to leave anything behind to cloud it up. Many folks have had luck with water and cleaning products like simple green, but I personally prefer DA. There is no reason not to try both, the DA may be to pungent if you do not have good ventilation, just keep in mind that the water will take days to dry completely and will look dark until it is dry. I gota say, you have your work cut out .. 133" is a lot of surface to clean.. GOOD LUCK!
garykagan 06-10-2012 06:12 AM
yeah - large area to clean. Thanks for all the info, I appreciate it. I hope it just is layers of dust at this point. 5 years ago I did try to clean it with water and it left streaks to this day. As long as the DA doesnt do any worse than the water did years ago to the coating I should be fine. I like the distilled water and large cotton towel approach - seems less potent than DA and I could set up a dehumidifier and a fan to dry it quick. Thinking of that as well.
Solfan 06-10-2012 05:47 PM
I posted here about the distilled water + clean white towel more than three years ago, and I haven't noticed anything out of the ordinary.... with normal viewing.
I just now carefully examined my HP again [with a 250-watt utility lamp, front-on and looking edge-to edge [almost completely off-axis, best way to see any faint horizontal issues] and it still looks absolutely perfect.
Solfan 06-10-2012 05:52 PM
PS I remember now that I cleaned the back surface, too... it's a retractable model... to prevent any dust/dirt transfer when (infrequently) rolled-up.
Nima 07-28-2012 01:51 AM
Did anyone else try it with the DA? What was the result?
airscapes 07-28-2012 04:23 AM
This may help you narrow down what it is called in Europe .. Just google "what is denatured alcohol called in Germany"
http://en.wikipedia.org/wiki/Denatured_alcohol
http://www.summitpost.org/phpBB3/denatured-alcohol-in-europe-t61936.html
http://www.rcgroups.com/forums/showthread.php?t=492787
http://www.talkbass.com/forum/f16/cant-find-denatured-alcohol-can-i-try-something-else-like-mineral-spirits-234183/
If you are concerned just use water but be forewarned it will not look good for a few days. My comments are for the 2.8 gain. the 2.4 will probably dry faster since there is a lot more room around microbeads for air flow.
Nima 07-29-2012 03:09 AM
Thank you very much airscapes, the 2nd thread answered all my questions. cool.gif
I have the 2.8 as well. Will try to get my hands on some DA here in Germany (it is apparently called "Brennspiritus" ) and try it on a tiny part of the screen first.
airscapes 07-29-2012 07:50 AM
Microfiber cloths, don't rub to hard, have projector on with all white image to help you see where you have and have not cleaned and for heaven sakes open the windows and DON'T smoke, the stuff is highly flammable!
airscapes 08-01-2012 07:05 AM
Nima, any update?
Nima 08-19-2012 08:13 AM
Taking a while. Got the DA now. Only problem now is I am not able to find white microfiber cloth in the shops around here. Might order some.
airscapes 08-19-2012 08:50 AM
Don't have to be white.. I have blue and white there should be no issue but you can test a colored cloth to make sure the it does not run.. Alcohol should not cause dyes to run.
Wilt 09-19-2012 12:45 AM
Hi
Is methylated spirit the right thing to use in the Uk? If yes, I see the color of the liquid is either blue or purple.
Is it the same for DA? Just worried about staining screen.
airscapes 09-19-2012 05:49 AM
Looks like methylated Sprites is the proper product but should be clear. I guess those manufactures have added die to prevent people from drinking it as water and dieing.
You can see a picture of a product with that name on the wiki site with no die and it look like a bottle of water! In the US it is typically packaged in metal cans you would expect solvents to come in and sold in the paint department next to the paint thinner, acetone and lacquer thinner.
Try and find some that is not died and if not possible, test the died product on a price of white printer paper. if the paper turns purple don't use it on the screen.
Good luck
Holiday121 09-19-2012 11:48 PM
116 Attachment(s)
If you dont mind me asking What kind of projectors you using with your HP screens and how far is the projector back from the screen.
airscapes 09-20-2012 04:21 AM
Projector is an old HC3000 720p DLP redface.gif that gets put on an accent table about 9' from a Projection King HP 2.8 4:3 portable that is mostly only opened to the 16:9 ratio. However, I have made a few modification to the screen that allows me to open to any ratio if I feel like it.
Unfortunately I don't have room for anything mounted on the wall or ceiling and this is all that will fit in the space I do have. at 16:9 it is only 65" diag. but if we are watching an old 4:3 DVD it will open to 72" Still tiny but it works for us in our living room.
couple of pics of screen area and projector
http://misc.airscapesart.com/velvet/index.html
Holiday121 12-11-2012 05:27 PM
116 Attachment(s)
I just seen I have a pretty big like smudge spot on my screen. Distiller water the way to go still?
airscapes 12-12-2012 07:23 AM
Water wont hurt but will take some time to dry and may not remove the spot.
Denatured Alcohol on a clean soft cloth should remove the make without damage to the surface.. please read this complete thread if you have not.
toddhbailey 06-04-2013 01:59 PM
any thoughts on 99% isopropyl ?
DA is quite spendy around these parts
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
