Screen Size - Opinion please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-23-2002, 09:53 AM - Thread Starter
tcat's Avatar
Quoted: 197 Post(s)
Liked: 93
I am in the planning stage of a HT. I have about 72" width to work with. I will probably use a rear projection, with something like an LS110. I have two options, please let me know pro's and cons of either. I'll be watching the variety of DVD formats, and many 4:3 VHS tapes, and maybe some Dish.
Option 1: 16:9 Design, a 40.5" x 72" opening in the wall. This will yield an 82.5" diag. 16:9 picture, a 38.9"x72" 1.85 picture, a 30.6"x72" 2.35 picture, and a 40.5"x54" 4:3 picture (67.5" diag.). Mask on sides for the 4:3 picture (or stretch), mask top and bottom for others.
Option 2: 4:3 Design, a 54" x 72" opening in the wall. This will yield a 90" diag. 4:3 picture, and the other size widescreens above. Masking top and bottom only.
I'm not even sure if masking is that important on rear projection. Projector will sit at approx. 10' and has zoom to take care of screen fill. Viewing 10'-12' away. I think the 16:9 design "looks" more like a HT, but the 4:3 design gives a 33% larger 4:3 image. Is 90" too big? Will I have better brightness if I choose opion #1?
tcat is online now
post #2 of 4 Old 01-24-2002, 02:26 PM
capstone's Avatar
VHS?!
You are going to be sorely disappointed if you take the time to hook up a VHS to a PJ. DirecTV gets screen door on my Infocus LP335 DLP PJ at around 90" and it has 425 rez. VHS is barely half that resolution.
As for the screen size, aspect ratio and such; sound like 4:3 is still the way to go, but be aware that masking for 16:9 will really improve your DVD's alot so factor that in, or realize you will notice the blacks seem washed out.
Cappy!
capstone is offline
post #3 of 4 Old 01-24-2002, 02:46 PM - Thread Starter
tcat's Avatar
Quoted: 197 Post(s)
Liked: 93
Thanks, Cappy. I didn't realize VHS is that bad. I guess my best bet for recorded movies is use my Dish 501 PVR, and/or rent the DVD.
VHS looks as good as Dish digital programming on my 32" Magnavox TV... you'd think a digital projector would be "smart" enogh to turn VHS into something watchable...
I was actually leaning towards the 16x9 screen and masking the sides for 4:3. A 54" tall image just seems like it would be too huge from 10' away. The widescreen would look more like a HT.
tcat is online now
post #4 of 4 Old 01-25-2002, 03:44 PM
thebland's Avatar
Quoted: 1493 Post(s)
Liked: 846
mask the 4:3. Go with widescreen. Format of the future (and present).
JEff
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
Closed Thread Screens
