Screen Gain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-25-2002, 09:28 AM - Thread Starter
edgartolerojr's Avatar
Hi ALL !!
How can I determine the screen gain to be use?
Is there any specific formula for CRT,DLP an LCD?
What Is the basis? Light output(ANSI LUMENS)?
Or depends on the projector to be use?
Any Idea?:confused:
Edgar
edgartolerojr is offline
post #2 of 7 Old 01-25-2002, 10:11 AM
David Panko's Avatar
Screen brightness (foot lamberts) = Projector brightness (lumens) / Screen Area (sq. feet) * Screen Gain
You should be targeting 16-22 foot lamberts if you have total light control, and more if you have ambient light in the room.
Dave.
David Panko is offline
post #3 of 7 Old 01-25-2002, 11:32 AM
Iceman's Avatar
True, but 10 ftL can also be enough for a VERY good viewing experience. Otherwise I agree with David, brighter is better (up to a point that is).
Iceman is offline
post #4 of 7 Old 01-25-2002, 03:26 PM
Luis Rodriguez's Avatar
I have a Barco 808s which I understand puts out about 250 ANSI lumens. According to this formula, I would need a gain of about 2.3 to get 16 ftL on an 8 foot wide 16x9 screen.
That seems kinda high. I understood that a high gain screen has some tradeoffs (color shift, host spotting, decreased viewing angle, etc..). Is there a point where these factors start to outweigh the brightness? I realize this is probably a mater of taste but is there not some general rule of thumb?
Luis Rodriguez is offline
post #5 of 7 Old 01-25-2002, 05:18 PM
KBK
KBK's Avatar
On a CRT projection system, getting above a screen gain of approximately 1.6 or so, gets you into an area where the gain consideration will intrude into the viewing experience, in my opinion. Higher gain is fine for retroreflective screens, but not for flat surface types, which are the kind we generally speak of here on the forum.
Ken Hotte
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
KBK is offline
post #6 of 7 Old 01-25-2002, 08:12 PM
steve5097's Avatar
CRTs can put out much higher flux over a small area than their total lumen rating suggests. You really don't need to average 12 ft-lam over an entire screen to have a good viewing experience.
Steve
steve5097 is offline
post #7 of 7 Old 01-27-2002, 05:18 PM
Art Sonneborn's Avatar
Quoted: 247 Post(s)
Liked: 308
I'm not sure but I think less than a year ago we were quoting 10 foot lamberts as the low end. That may not sound like a giant difference but that 20% can really make a difference in recommended screen dimension as well in selecting a perf screen or not .
Art
My HT
iRule rules my theater
Art Sonneborn is offline
Closed Thread Screens
