I need a screen material that is OK rolled... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-29-2002, 08:28 PM - Thread Starter
heathyoung's Avatar
Hey all...
just getting a new house and need a screen material that is OK rolled. This is because I am looking at making a motorised screen that will hang from the ceiling.
I looked at the price of the screens and was somewhat supised at the cost of a motorised screen! Even a pull down screen is a bit too costly for my liking.
So, I have the basic idea for the controller and motor - I just need a good material for the screen.
Someone mentioned blackout/blockout fabric - what is this? This was some sort of curtain material IIRC?
Heath Young
heathyoung is offline
post #2 of 2 Old 02-01-2002, 05:20 AM
RJM3's Avatar
Try gessoed artist's canvas. You can buy it by the roll. It comes rolled up and if you don't use a too small diameter of a rod (I'd use the tube it comes in) you should be ok. It has the advantage of being pure white (it's meant for paint picture-it has to be pure) and completely uniform. It's a 1.0 gain screen which is perfect for an lcd or dlp projector.
Bob
RJM3 is offline
Closed Thread Screens
