So do the pull downs and remote screens sway from air flow? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-25-2009, 12:33 PM - Thread Starter
htttrh's Avatar
Didnt see anyone really touch on this subject. I have a 106" fixed screen now but wife asked me about getting a pull down (manual is fine) but Im curious if there is any airflow in the room such as a ceiling fan does the screen move about? That would drive me insane.
If any of you can give me some pros/cons or advice on this since I know plenty of you have already travelled this road before, Id appreciate it! Thanks
htttrh is offline
post #2 of 3 Old 08-25-2009, 01:07 PM
lewke's Avatar
If the airflow is strong enough it'll move it, i have a vent under my screen that I have to cover up or it'll move the screen......
Also pull down screens are subject to develop waves, luckily it hasn't happen to mine.......
lewke is offline
post #3 of 3 Old 08-25-2009, 03:15 PM
cdnewmanpac's Avatar
I had both a manual pulldown and electric retractable that would move if the ceiling fan located about 6 ft away was set at 4,5 or 6 out of 6. My tab tensioned screen (which is much heavier) does not move until 6 (which is noisy enough to be inappropriate for watching movies anyway).
My fan has a remote: I've programmed my Harmony to lower the fan speed to 3 when I hit the "watch movie" or "watch TV" buttons.
cdnewmanpac is offline
Reply Screens
