How to Choose a Flat Panel TV, LCD or Plasma? - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2009, 05:05 AM - Thread Starter
hihi2009's Avatar
True false question!
Even if these differences exist, however they tend to fade over the improvements in digital processing, and the question of opting for an LCD or plasma can not find his answer in the depth of black or latency. In reality, they are more manufacturing constraints that will guide your choices, because LCD panels exceeding 40 inches are not plenty, while in contrast, plasma screens with a size less than 50 inches are virtually no on the market. So the space you have in your living room and the budget that is yours that make the difference predominantly in relation to choice of technology. Finally, you are faced with a situation where you have little choice but where space constraints and budget cut for you....
hihi2009 is offline
