Carada, Da-Lite, Elite, Seymour AV And Stewart Screen Material Test Results - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 11-20-2009, 08:18 AM - Thread Starter
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
umr is offline
post #2 of 31 Old 11-20-2009, 08:49 AM
scottyb's Avatar
Quoted: 27 Post(s)
Wow!! Nice report!!!
scottyb is offline
post #3 of 31 Old 11-20-2009, 08:53 AM - Thread Starter
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
umr is offline
post #4 of 31 Old 11-20-2009, 01:45 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 248
Yes. Excellent work Jeff.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #5 of 31 Old 11-20-2009, 02:05 PM - Thread Starter
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
umr is offline
post #6 of 31 Old 11-20-2009, 02:41 PM
Quoted: 146 Post(s)
Liked: 248
Screen Excellence too. I've heard their EN4 weave is very fine and almost looks solid but that the screen has a yellowish tint.
post #7 of 31 Old 11-20-2009, 04:40 PM
Samaritano's Avatar
... and maybe Vutec too.
Edgar
Samaritano is offline
post #8 of 31 Old 11-20-2009, 04:48 PM
Samaritano's Avatar
W. Jeff. Between the Carada Brilliant White material and the Elite CineWhite which one do you prefer? And thank you for taking the time to do these screen sample evaluation. They are really helpful.
Edgar
post #9 of 31 Old 11-20-2009, 05:15 PM - Thread Starter
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
I would go with the Carada Classic Cinema White or SnoMatte instead of those.
umr is offline
post #10 of 31 Old 11-20-2009, 05:33 PM
Samaritano's Avatar
Thank you W. Jeff. I'm contacting Carada for a Criterion 2.37:1 aspect ratio screen.
Edgar
post #11 of 31 Old 11-20-2009, 05:35 PM - Thread Starter
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
umr is offline
post #12 of 31 Old 11-20-2009, 06:19 PM
Samaritano's Avatar
I have various screen samples from different screen companies, including Carada, Da-lite, Stewart and Elite. I really like the Studiotek 100 but besides the price I'm afraid of the warning that it can only be used in a batcave.
The Studiotek 130 sample I can see sheen or sparklies on really bright scenes and the Elite CineWhite I like because of price and it looks similar to the Carada Brilliant White. I like the black backing to but I don't know if it offers any advantage over the Carada's.
Edgar
post #13 of 31 Old 11-20-2009, 06:25 PM - Thread Starter
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
The bat cave comment is pretty general to a good home theater. If you do not have that I would be very careful. Only the StudioTek is likely to have must chance outside of a dark environment or generous wall spacing. The black backing can help if you can see light leaking through the screen.
umr is offline
post #14 of 31 Old 11-20-2009, 06:52 PM
Jason Turk's Avatar
Originally Posted by umr View Post
Now if I could just get SMX and Screen Research samples.
Drop me a line Monday. I can help.
Jason Turk is offline
post #15 of 31 Old 12-21-2009, 01:10 PM
bigbaldguy's Avatar
I can assure you that there is NOTHING yellow about any of the Screen Excellence Enlightor (EN1, EN2 and EN4K) materials.
In fact, EN4K has just recently passed ISF certification (for colorimetry and uniform field of white at all points on the screen - on and off axis). Expect Screen Excellence factory to begin promoting this certification in the first Q of 2010.
You are always welcome to contact me offline here for screen swatch samples which include audio and video testing curves.
Good listening and viewing!
John
John Caldwell
President
Grace Motif, Inc
Scottsdale, AZ
www.gracemotif.com
tel: 480-463-4248
fax: 805-856-2212
bigbaldguy is offline
post #16 of 31 Old 12-21-2009, 01:55 PM
bigbaldguy's Avatar
Here's a little photo that will show you a close up shot of the Screen Excellence Enlightor Series of AT screen fabrics (generally: EN1 = 1080 material, EN2 = 720 material and EN4K = 4K material.) also shown is a piece of traditional vinyl micro-perf for comparison.
Good listening and viewing.
John Caldwell
President
Grace Motif, Inc
Scottsdale, AZ
www.gracemotif.com
tel: 480-463-4248
fax: 805-856-2212
post #17 of 31 Old 12-21-2009, 01:56 PM
bigbaldguy's Avatar
http://www.flickr.com/photos/33721363@N00/4204623492/
John Caldwell
President
Grace Motif, Inc
Scottsdale, AZ
www.gracemotif.com
tel: 480-463-4248
fax: 805-856-2212
post #18 of 31 Old 12-21-2009, 05:27 PM
FLBoy's Avatar
Quoted: 13 Post(s)
"Screens with gain may perform better than that observed if the projector is mounted closer to the observers eye level."
The preceding quote taken from your otherwise excellent report is not 100% accurate. It is absolutely accurate for retroreflective screens, such as the Da-Lite High Power. It is not quite right for angular reflective screens, such as most of the other screens in your report. Angular reflective screens exhibit the greatest gain at screen center when the angle between the projector's line of sight above screen center and a line perpendicular to screen center is equal to the angle between the viewer's line of sight below screen center and a line perpendicular to screen center. In other words, if the viewer's line of sight is 10 degrees below screen center, a projector position 10 degrees above screen center will produce the greatest gain at screen center. Anything closer to (or further from) the viewer's eye level will produce less gain.
Your statement is true for both types of screens only when the viewer's eyes are at screen center height (which may?? be true for your theater). In the general case, in which the viewer's eyes may not be at screen center height, your statement is not true for angular reflective screens.
You don't have to take my word for this. If you move your measurement device below any angular reflective screen at an angle below screen center equal to the angle of your projector above screen center, you will find that to be the point of maximum gain for a point at screen center. (Angle of reflection equals angle of incidence.)
FLBoy is offline
post #19 of 31 Old 12-26-2009, 03:26 PM
dxmartin's Avatar
Thanks Jeff, very useful.
Do you plan on reviewing the SI Black Diamond screens? They appear to be a better solution than the studiotek 130 for rooms with ambient light.
D.
dxmartin is offline
post #20 of 31 Old 05-13-2010, 10:11 AM
Brad Horstkotte's Avatar
Liked: 72
Interesting report - any idea what might explain, for the Seymour AT fabric, why it measured at 0.94 gain, but their site says 1.2? Or am I misreading that?
Brad Horstkotte is offline
post #21 of 31 Old 05-16-2010, 09:10 PM
andrios's Avatar
Ya looks like lots of the manufacture gains are off.
andrios is offline
post #22 of 31 Old 02-03-2014, 12:47 AM
nathan_h's Avatar
Quoted: 1439 Post(s)
Liked: 927
Sorry to bring this thread back to life. But in reading the report I don't see Seymour discussed. And given the age of the posts, is this the prior Seymour at material?
My current setup.
My favorite movie review podcast, the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is online now
post #23 of 31 Old 02-03-2014, 02:34 PM
Quoted: 146 Post(s)
Liked: 248
I'm pretty sure it was the centerstage XD material used.
post #24 of 31 Old 02-03-2014, 06:40 PM
Mike Garrett's Avatar
Quoted: 6955 Post(s)
Liked: 4645
mjgarrett100@gmail.com
Mike Garrett is online now
post #25 of 31 Old 02-03-2014, 07:01 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4014 Post(s)
Liked: 4072
Jeff is stopping by my theater in a week and a half, to touch up my Lumis. I'm going to have him check out the Neve 1.1 screen, and give him some Neve and HD Pro 1.1 and 1.3 screen samples, so he can add those to his data base.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #26 of 31 Old 02-04-2014, 08:55 PM
nathan_h's Avatar
Liked: 927
Thanks. It's not in he PDF in the first post. Maybe because I'm reading this in a mobile device....
That's disappointing, either way. Well, I'll reserve judgment until I get the sample I have ordered.
Apparently their newer 4k friendly weave has even less gain!
My current setup.
post #27 of 31 Old 02-05-2014, 04:49 PM
Quoted: 146 Post(s)
Liked: 248
It's a great screen material even if it doesn't measure at the spec'd gain.
I think the sample Jeff used was the piece I brought him when he calibrated my old JVC RS35. I was living in Canada at the time and drove down to Buffalo with another guy in Toronto to get our projectors calibrated by Jeff. I had a few feet of the centerstage XD material left over from my screen build so I built a little frame and made a 2' or 3' square screen so he could accurately calibrate my projector and then left the screen sample with him for testing.
post #28 of 31 Old 02-05-2014, 07:20 PM
nathan_h's Avatar
Liked: 927
And if one believes their tests, it's the highest gain weave material on the market.
My current setup.
post #29 of 31 Old 02-13-2014, 08:53 AM
nathan_h's Avatar
Liked: 927
For those who are interested, the latest report is here
http://www.accucalhd.com/documents/accucal_front_projection_screen_report.pdf
and includes lots of screens missing from the old report, including a lot of AT screens.
cgott42 likes this.
My current setup.
post #30 of 31 Old 02-13-2014, 09:06 AM
cgott42's Avatar
Quoted: 156 Post(s)
thanks - one typo to be aware of - on page 6 - 1st line - I think you meant to say "Acoustically Transparent" (without the "Non")
cgott42 is offline
Reply Screens
