Moire with elite acousticpro? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-20-2009, 10:21 AM - Thread Starter
floridapoolboy's Avatar
Now that I have a new Viewsonic Pro8100 I want to upgrade my screen. The power zoom and lens shift enable me to do the 'zoom" method, so I want to go 2.35:1, with as large a screen as my room will allow. My viewing wall is 154" wide, and my seating is at 13"10". To maximize the screen I want to build a false wall 18" out and go with a 125" Elite AcousticPro screen. My speakers could then go behind the screen, rather than being stuffed into a corner. The only concern I have is moire from the woven fabric of the AT screen. My pj is ceiling mounted about 13'6" from the wall, which would be reduced to 12 feet after the false wall is built. Anyone try this screen? Should I be worried about moire, since the screen purchase is a final sale I'd hate to do all this and get a bad picture. My other alternative is to go with a smaller Carada 2.35:1 screen and not do the AT false wall thing. Any input would be helpful, thanks!
floridapoolboy is offline
post #2 of 14 Old 12-20-2009, 07:12 PM
Fabricator's Avatar
Quoted: 71 Post(s)
Liked: 33
did you test to see if it will throw 125" from 12' ? i want a 119", and i am pushin it at 13".
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
post #3 of 14 Old 12-20-2009, 08:08 PM - Thread Starter
Good point, it works fine at 13'6", but I have plenty of room to move the pj back another 18" if need be. I just need to hear about the image with the Elite screen! I received a pm from a Seymour dealer, that's another option. Of course, then I'd need to ask the same question about the Seymour AT screen!
post #4 of 14 Old 12-20-2009, 08:20 PM
Fabricator's Avatar
Quoted: 71 Post(s)
Liked: 33
i remember reading a thread, where the guy had a problem with lines. iirc, the fix was to turn the screen a little. like a wall picture that needs to be straightened.
idk if that will help ya. but there it is
post #5 of 14 Old 12-20-2009, 08:39 PM - Thread Starter
Yeah, that's fine for DIY, but with a store bought screen the fabric is what it is, no option. I've been researching the Seymour screens, that's sounding interesting! A bit more money, but they say they are free of moire, which is very important to me. I'm not gonna give up picture quality to go AT, that's fer sure!
post #6 of 14 Old 12-20-2009, 08:44 PM
Fabricator's Avatar
Quoted: 71 Post(s)
Liked: 33
i hear ya ! GOTTA have that VS PQ !!! you gonna order samples ?
post #7 of 14 Old 12-20-2009, 08:51 PM - Thread Starter
Yeah, that would be the smart thing to do. Of course, most samples are so small moire wouldn't show, but at least I'll get an idea. I'm getting psyched about a 125" diag 2.35:1 AT screen, man that would blow away my 96" 16:9!
post #8 of 14 Old 12-20-2009, 09:01 PM
Fabricator's Avatar
Quoted: 71 Post(s)
Liked: 33
lol. i'm runnin a 98"ish diy. looks darn good. and it is big enough. but i want bigger ! lol
so i know what you mean. i'm looking at a HP.
post #9 of 14 Old 12-21-2009, 05:57 AM
umr
umr's Avatar
Quoted: 41 Post(s)
Liked: 78
I have a sample of this material and will post the results in a few weeks. Look at 1080 line pattern to see if you get moire.
umr is offline
post #10 of 14 Old 06-28-2011, 01:40 PM
microsup's Avatar
Did you check for moire yet?
I just ordered elite r120 acousticpro 1080
So wonder about possible moire
microsup is offline
post #11 of 14 Old 02-11-2013, 08:37 PM
jimmyk36's Avatar
Quoted: 89 Post(s)
Liked: 41
Microsup - how did you AT screen turn out?
jimmyk36 is offline
post #12 of 14 Old 02-12-2013, 08:52 AM
microsup's Avatar
Screen works fine, no moire. Some times on a very bright scenes you can see that screen is not solid surface, but that is not destroying a picture.
microsup is offline
post #13 of 14 Old 02-12-2013, 09:37 AM
Yzfbossman's Avatar
Quoted: 45 Post(s)
Liked: 75
What is your seating distance? Thanks
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #14 of 14 Old 02-12-2013, 11:26 AM
microsup's Avatar
about 12 feet. and screen size 120" 16x9
microsup is offline
Reply Screens
