Stewart Masking Screen Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-27-2002, 05:21 AM - Thread Starter
sbaillar's Avatar
I was wondering if anybody has the 4 way masking screen from Stewart?
Does it come in 2.35:1? Firehawk/Greyhawk? What triggers the size difference?
Do I really need a 4 way with constant height?
sbaillar is offline
post #2 of 2 Old 02-27-2002, 06:50 AM
fr8flyr's Avatar
I have a Stewart Ultimate 4Way screen. Yes it can be ordered in GrayHawk, that is the way I ordered mine, and I assume it will be available in FireHawk as well. The horizontal masking works from a 12volt trigger and is either up or down. The vertical masking is multi-adjustable and can be ordered with different options for activation such as remote control or wall switch. If you are going to go with a 2:35 screen, constant height, setup the Ultimate 4Way is not going to work for you. You will have to come up with some means to multi-adjust the horizontal masking for the different aspect ratios. The ultimate is not set up for this but I don’t know if Stewart could make something for you.
Earl
fr8flyr is offline
Closed Thread Screens
